Results 1 to 10 of 19
Thread: E:24 - Won't drain
    Feb 2006
    Alabama
    Default E:24 - Won't drain
    Model Number: SHE6AF02UC/05
    Brand: Bosch
    OK, I have a almost new Bosch dishwasher that won't drain. I've checked the lines for blockage and can't find anything all the way to the big pipe going into the main house drain. It's been working in the past so I know the line works. Anything other than potential line blockages I need to check?
    P
    Apr 2012
    florida
    if you can hear the drain pump turning it may be clogged--the bosch has a round micro-filter that has to be turned and locked in to avoid clogging the drain/wash pump. if it was run without properly being locked, it won't take much to stop it up---i think i saw 3 coffee beans stop one completely--check the filter in the bottom of the unit--the round one you unscrew--you may need to use a wet vac to empty the machine--look down in the hole the filter came out of and check for any debris, use a long screw driver to pry anything that maybe stuck out of the inlet holes and vacuum out--also check that filter for clogs--and make sure it gets installed properly------cheers
    Feb 2006
    Alabama
    Well, I went in initially and vacuumed everything out and cleared the lines. I didn't find any debris blocking but it cleared the error and everything started working again. Then last week it started acting up again. Again, I went in and cleared everything from the filter to the main drain line and again didn't find any debris but this time I can't get the E:24 to clear. The pump sounds like it's working and in fact when I run the quick rinse cycle and watch the drain line I can see some of the water drain. But at the end of the cycle, it doesn't finish draining everything out and throws the error. Any thoughts?
    Feb 2006
    Alabama
    *bump* - still having this issue...
    Jeff helps us with these Bosch products, I msged him to see if he can assist you.
    Oct 2004
    SHE6AF02UC/05
    Can get past that 6, appears too new for most of my info....I have sheets on the 5 ( SHE5 ) versions.
    E:24
    E:24 No drain flow possible �� Drain pump is running but unable to remove the water, drain system blockage. �� Check for blockage of drain hose
    E:25 says jammed drain pump.
    *If* the drain is 100% ok, can't think of much besides trying a new drain pump.
    Drain pump Manufacturer Number 611332
    Drain Pump 611332 Order now for same day shipping. 365 day return policy. RepairClinic.com
    http://www.applianceaid.com/
    Appliance Repair Aid
    Sep 2012
    Utah
    I'm having the E:25 error on my dishwasher. The problem is intermittent. I've pulled the drain line apart, removed and inspected the drain pump without finding an issue. Everything is seated properly, the filter looks fine. The error usually doesn't occur during a quick wash. When it does stop draining, I can just start a quick wash and cancel and it will drain normally. I believe the manual says it could be the pump or power module, but I'm not sure. Any ideas? Thanks
    Oct 2004
    Model#?
    Sep 2012
    Utah
    Quote Originally Posted by jeff1 View Post
    Model#?
    It's a SHE6AF02UC/05, same model as the OP
    Oct 2004
    Quote Originally Posted by allstick View Post
    Can't get past that 6, appears too new for most of my info....I have sheets on the 5 ( SHE5 ) versions.
    Sorry can't help more.
  1. FIXED: Kenmore 665 won't drain on full cycle but drains on cancel drain
    By wetdishes in forum Sears Kenmore
    Last Post: October 23rd, 2013, 04:15 AM
  2. Replies: 10
    Last Post: March 12th, 2012, 09:19 AM
  3. maytag dishwasher turns on, fills and thats all. will drain if I push the drain button
    By leenabug in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 29th, 2012, 10:35 AM
  4. FIXED: Maytag MDB5601AWQ - drain motor hums but will not drain
    By mikkig77 in forum Dishwashers
    Last Post: December 1st, 2011, 11:02 PM
  5. Maytag D/W: - drain after wash issue but cancel/drain works fine after....
    By disan2011 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 11th, 2011, 11:04 AM
