Results 1 to 5 of 5
Thread: Kenmore Elite HE4 dryer stopping with clothes still wet
    Apr 2012
    florida
    Default Kenmore Elite HE4 dryer stopping with clothes still wet
    Model Number: 110.85866400
    Our dryer shuts off in the middle of the Manual cycle with the clothes still wet. Once the dryer cools down it will start up again. If we run on Med temp it seems to run okay for now. We have blown out the lint on both the Dryer and house so we know its not blocked.
    It seems to be the high temp. Its like it is overheating and shutting down.
    Should we replace the heating elment? or the thermosat.. and can you provide the part number and where it is at.
    Thank you so much
    Oct 2004
    HE4 is not a model#.
    LINK> Where is my model#, I need a part, where should I look for my model number
    The motor shuts off in the middle of the cycle?...and won't restart unitl it has sat a while cooling?...if yes, it sounds more like a motor going sour and hsutting on on it's built in safety/thermal switch.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Apr 2012
    florida
    model # is 110.85866400
    Quote Originally Posted by kimhen View Post
    Thank you so much
    Apr 2012
    florida
    What happens is it seems to get hot and will stop then once it cools down it starts back up. If you see it and push the start button it will beep 3 times and nothing will happen. It will only restart once it has cooled down.
    But If you select the Med temp level it runs the entire cycle fine with no issues.
    So if your thinking it the motor I guess I'll need the part number for the motor.
    Thank you for all your help.
    Oct 2004
    3 beeps is sometimes the temp thermistor...check it first...
Size:  2.5 KB Dryer thermistor assembly Manufacturer Number 8577274
    Failing that...
ID:	4981 Motor, dryer drum drive Manufacturer Number 279787
  1. Kenmore Elite Washer/Dryer makes clothes stink
    By ominosity in forum Sears Kenmore
    Last Post: December 1st, 2013, 09:00 PM
  2. Replies: 22
    Last Post: August 8th, 2010, 01:15 PM
  3. Kenmore Elite Dryer Twists Clothes - Help!
    By mvlighthouse in forum Sears Kenmore
    Last Post: February 28th, 2007, 03:33 PM
  4. Kenmore Elite Dryer not drying clothes....
    By beijin1 in forum Sears Kenmore
    Last Post: December 30th, 2005, 11:01 PM
  5. Kenmore Elite dryer keeps stopping
    By shirleypelicanfun in forum Sears Kenmore
    Last Post: September 16th, 2005, 01:58 AM
