Results 1 to 2 of 2
Thread: door gasket for imperial hd commercial freezer
    May 2012
    Texas
    Smile door gasket for imperial hd commercial freezer
    Model Number: UL2493ECW5
    Brand: other
    Age: More than 10 years
    Hi, I have a old imperial heavy duty commercial freezer. The door gasket must need replacing as the door is hard to open. Ice crystals have formed all around the door opening. It's an incredible freezer so I want to fix the problem. It's. Model # UL2493ECW5.
    I looked up that model number on ur website and 2 different gaskets are priced $ range of approximately 75.00 to 135.000.
    How do I know which one fits my freezer. Would love the lower priced one. But I want the right part. To keep my freezer going
    Which part fits my freezer. Help.
    Thank you.
    Does the door seem heavy and hard to open? I have seen many get all iced up inside the door and cause the door panel to also crack, check the door panel first, check under the inside door gasket lip to see the door liner if its cracked all around it.
    Looks like they have an original door gasket and a substitute which is the lower priced one, it measures the same as the original, so it should be fine:
    Freezer Door Gasket 3206261 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. Bad freezer-door gasket? And how to replace, if so
    By dpath in forum Whirlpool/Roper/Estate
    Last Post: June 27th, 2010, 10:24 PM
  2. 106.50593003 freezer door gasket replacement
    By ezmendriz in forum Sears Kenmore
    Last Post: June 8th, 2010, 12:02 PM
  3. Commercial Freezer vs. Regular
    By dousterhout in forum Refrigerators & Freezers
    Last Post: April 30th, 2010, 07:47 PM
  4. Imperial HD Commercial freezer
    By shad0704 in forum Refrigerators & Freezers
    Last Post: April 6th, 2007, 08:09 AM
  5. Replacing a freezer door gasket
    By Lauralyn1 in forum Refrigerators & Freezers
    Last Post: August 6th, 2006, 10:37 AM
