Results 1 to 10 of 13
Thread: Microwave fuse keeps blowing
    May 2012
    Australia
    Default Microwave fuse keeps blowing
    Model Number: nn-8550
    Brand: -major brand-
    Age: More than 10 years
    Have a Panasomnic NN-8550 microwave that, to quote the boss "made a funny noise and stopped working". When I looked at it, there was no power; even the display was dead.
    Pulled the cover off, the fuse was blown, so replaced it. When I plugged it back in the display powered up as per normal and I could set the power level and time as usual. When I pressed start it sounded like normal and seemed ok, but after about 1 sec there were 3 or 4 clunking sounds then it stopped working and went dead. The fuse had blown again.
    I have checked the thermal cutout with my basic multimeter (seems fine) and I took the capacitor with me to the electrical store when I got some more fuses and they tested it for me and said it was within tolerance.
    From what I have read, it doesn't sound like it is the Magnetron and I haven't tested the diode as I am not sure how to.
    I am a novice with microwaves so hope there may be some knowledgeable people out there that may be able to suggest what I should do next to identify the cause.
    thanks
    Oct 2004
    More often than not, a shorted high voltage capacitor.
    Quote:
    I took the capacitor with me to Jaycar when I got some more fuses. They tested it for me and said it was within tolerance.
    Check it again.
    http://www.applianceaid.com/micro4.html
    Quote:
    From what I have read, it doesn't sond like it is the Magnetron and I haven't tested the diode as I am not sure how to.
    Usually the mag or diode won't blow the fuse, they may growl or make a strange noise and stop heating but normally don't blow the fuse.
    Testing...
    http://www.applianceaid.com/component.html
    If needed:
    Capacitor, hv Manufacturer Number A60905500AP
    Appliance Repair Aid
    May 2012
    Australia
    Default Capacitor
    Quote:
    Thanks Jeff,
    I have pulled the capacitor out of the microwave again and have tried to test with my digital m/meter. Have followed the instuction on your link, however have a couple of questions.
    1st up, the instructions suggest setting on Rx1. My m/meter has 20M, 200k, 20k, 2000, 200 settings. Internet research says that Rx1 is equivalent to 200. Is that correct?
    2nd, the testing instructions say to "touch the cap terminals ( red lead on left and black lead on right )" Excuse my ignornace, but that is a bit confusing for me. 'doh! As I look at the capacitor as it would be positioned in place in the microwave, there are 2 caps. The left side has 3 terminals and the right hand side has 1. When I connect the red m/meter lead to any 1 of the 3 terminals on the left cap and the black lead to the terminal on the right cap, the reading stays on 1 and doesn't change at all. When I reverse the red and black leads, the reading again stays on 1.
    I am not sure if I am testing the capacitor correctly or whether the capacitor needs to be replaced. BTW, the capacitor is not out of shape or bloated and there are no signs of any oil.
    Hoping someone can help with the next steps. Thanks.
    Oct 2004
    Needle meter is used...especially for microwave stuff...that's all we use.
    Normally wouldn't be.
    Not really.
    What does your meter say when you put the two meter leads together?
    May 2012
    Australia
    thanks Jeff, I only have the digital version.
    Not really.
    When I put the leads together, it reads 00.4 or 00.5
    thanks Jeff
    Ian
    Jul 2006
    See if this helps:
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2012
    Australia
    Quote Originally Posted by rickgburton View Post
    See if this helps:
    Thanks for making it simple for me Rick.
    Set the m/meter to 2000
    Touched tthe probes together and reading was 000
    Then put one probe on A and other on B - reading did not change at all and continued to show 1
    Swapped probes and again reading did not change and continued to show 1
    Do you think that means the capacitor needs replacing?
    Jul 2006
    If the meter didn't change, replace it. Use the link jeff1 gave you.
    Oct 2004
    Which is wrong, should read 0.
    For what ever reason it is showing open....only thing to do is swap out the capacitor and forget the meter testing.
    May 2012
    Australia
    Thanks for your help Rick and Jeff. Will replace the capacitor and let you know how it goes.
    cheers
  1. Why my microwave is blowing internal fuse?
    By adol66 in forum Whirlpool/KitchenAid
    Last Post: February 27th, 2012, 07:55 PM
  2. Whirlpool microwave blowing fuse
    By phil25rs in forum Whirlpool/KitchenAid
    Last Post: December 31st, 2010, 07:38 PM
  3. Blowing house fuse
    By pucara in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 15th, 2010, 10:30 AM
  4. Kenmore Microwave Oven Fuse Keeps Blowing
    By Belligerent in forum Sears Kenmore
    Last Post: June 7th, 2005, 11:54 AM
  5. Kenmore Microwave Oven Fuse Keeps Blowing
    By Belligerent in forum Sears Kenmore Reviews
    Last Post: December 31st, 1969, 06:00 PM
