Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Samsung OTR Micro door latch mechanism broke
    Jan 2008
    NC
    Default Samsung OTR Micro door latch mechanism broke
    Model Number: SMH9207ST
    Brand: Samsung
    All - I opened the door to my OTR Samsung microwave, model SMH9207ST on Friday and I heard a pop and noise like a spring coming undone and parts rattling inside the door. I then closed it and it wouldn't stay closed. I see there are two hook latches that should be spring loaded, but now they just float freely with no tension. Any assistance on how to tackle disassembling this micro door and repairing the latch mechanism would be much appreciated!! Thanks.
    David
    Oct 2004
    Jan 2008
    NC
    Thanks Jeff! Any additional guidance on how I should first start to remove the inner trim piece (eg., start at middle bottom and move putty knife until a clip is felt and then pry up (or down), or??) That looks like the door key of my unit.
    Cheers - David
    Oct 2004
    Exactly....I start in one spot and if it comes out I go with it.....if too much resistance I move and start in a different spot.
    prying out towards you.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jan 2008
    NC
    Thanks again Jeff - I'll start on it tonight and let you know..
    Oct 2004
    Please do let us know how you make out with it
    Aug 2012
    grass valley ca
    had the same problem. I removed the inner trim piece, as recommended above (thanks for that!) and found that the spring connection on the latch piece had broken. I tried drilliing a 3/64th inch hole on the "ear" of the latch near where the spring had connected, then connected the spring, put it back together .... and it works fine.
    Oct 2004
    Yupper, found a few broken and couple of spring hoops broken.....things to try our patience
    Thankx for letting us know.
    Jan 2008
    NC
    Quote Originally Posted by newpewter View Post
    Thought I had replied. I did the exact same thing as newpewter - drilled a small hole where the "L" hook cracked off and reattached the spring and it is working fine!
    Oct 2004
    Glad to hear it is working again
  1. door latch broken can't open door
    By twz in forum KitchenAid
    Last Post: February 10th, 2013, 05:04 PM
  2. Replies: 4
    Last Post: April 23rd, 2012, 02:09 PM
  3. Replace latch on oven/micro combo
    By BadCujo in forum KitchenAid
    Last Post: January 31st, 2012, 03:31 PM
  4. Micro hums when door closed
    By upalms in forum Sears Kenmore
    Last Post: November 29th, 2011, 05:56 AM
  5. Quiet Partner III - top washing mechanism broke off!
    By mphilly in forum Whirlpool/Roper/Estate
    Last Post: July 10th, 2011, 09:54 PM
