Results 1 to 9 of 9
Thread: Whirlpool Oven Will not Self Clean Error Code E1 F5
    May 2012
    Kansas
    Default Whirlpool Oven Will not Self Clean Error Code E1 F5
    Model Number: RF386PXGQ0
    Age: More than 10 years
    Hello, we have a Whirlpool oven that will no longer self clean, after the self clean is started the Error Code E1 F5 is diaplayed on the readout, I have searched the web and have found different issues with different model's stating that there may be a problem with the latch assy. I worked the latch assy with the power off and the back cover removed and there is no obstruction of the mechanism. I have tried to hold the cancel button to display the error code to display the the code, then pressed again to Supposedly clear the error, but if I Press any button to get the code to change nothing happens after 1 min. of holding down any button. I'm at a loss, Is it possible that the Solenoid Assy is bad? Can anyone help? Thanx.................
    Yes, that error code indicates you will need a new lock solenoid assembly.
    We need the full model#, click here to locate it: http://www.repairclinic.com
    May 2012
    Kansas
    Default Lock Solenoid Assy
    Hey Jake, thank you for the quick responce, it is a Whirlpool: RF386PXGQ-0 S/N: RH4416171
    I believe the P/N for that assy, if that is exactly what I need is a 3196125. I had checked the latch mechanism and nothing appears to be binding in any way, by manually pulling on the latch the door locks and unlocks with the power removed of course. Please tell me what I need to order for sure, if that is it then Great, thank you. Please advise when you can.
    Marc
    Yup, thats it.
    You can order it here:
    Whirlpool 3196125 Solenoid Assembly - AppliancePartsPros.com
    All parts you order through our links and banners come with a 365 day full refund if you install the part/parts and it doesn't solve the problem.
    May 2012
    Kansas
    Hey Jake, is there a way to test the solenoid by applying a voltage? if so what voltage would it take to cause the solenoid to engauge?
    Please let me know when you can, thanks.
    Marc
    I don't know Marc, I've never direct tested it like that before.
    It should be just standard 120 volts to engage the solenoid, no harm to try.
    Jan 2014
    Bethlehem
    HI Guys: I'm having the same problem. I found the part linked above. Question. How do you get the side panel off to replace the solenoid? I've already had the back top panel off to replace the keypad, but don't see a way to get to that side panel. Thanks.. Chris
    Nov 2015
    West Hartford
    Default Clean Clean Clean
    Quote Originally Posted by Chicagoish View Post
    I had a similar issue ( E1 F5) and there was dirt and dust and cat hair that was around the door latch area. I vacuumed and cleaned and the error code went away.
    Hi Chris,
    Its located in the very back of your range, behind the back access panel.
    Unplug your range first!
  1. Replies: 8
    Last Post: March 27th, 2012, 07:06 PM
  2. Replies: 3
    Last Post: November 1st, 2010, 12:25 AM
  3. Whirlpool Double oven shows error code E6 F2
    By MLD7212 in forum Whirlpool/Roper
    Last Post: September 23rd, 2009, 07:40 PM
  4. Whirlpool Oven F3 Error Code
    By salacy in forum Whirlpool/Roper
    Last Post: September 7th, 2007, 05:27 PM
  5. FIXED: Whirlpool oven error code F3 E2
    By mlamont in forum Whirlpool/Roper
    Last Post: January 22nd, 2006, 03:18 PM
