Results 1 to 6 of 6
Thread: Whirlpool Washer Ultimate Care ii
    Jun 2011
    Atlanta
    Default Whirlpool Washer Ultimate Care ii
    Model Number: SM 8280867
    Hello,
    The washer seems to work fine during wash cycle but when i turn the timer to rinse or spin cycle it seems to do nothing. I have been researching other forums but not sure if I need to replace the timer or the lid switch. How do i know if the timer is not working properly? Sorry I cannot seem to find the model number right now. This is the Ultimate Care II Quiet Wash, 9 Cycles, 5 Speed Combinations.
    Thanks for your help.
    Click here to locate the model#: Help Me Find My Model Number - RepairClinic.com
    Does it drain the water fine and just not spin?
    When you move the timer to rinse it should fill with cold water, its not doing that? But is filling with cold water in the wash cycle?
    Jun 2011
    Atlanta
    The water does not drain, nor does it fill with cold water when I move the timer to rinse. Yes seems to be filling with cold water in the wash cycle.
    When you close your lid, do you hear a click sound just before it shuts? If not, then its your lid switch.
    If so, then its your timer.
    Jun 2011
    Atlanta
    Hi Jake,
    When we close the hid we do not hear a click. Can you please send me the link for the part.
    Thanks again for your help.
    Thats the problem, I can't link you to the correct part without a model#.
    You will need to remove the lid switch assembly and read me the part# thats stamped on it.
    Watch this video to remove it:
  1. Whirlpool Ultimate Care II Washer - Bottom agitates, top does not
    By NovaKnowledgeNow in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 13th, 2012, 06:12 PM
  2. whirlpool ultimate care II washer problems
    By Donny Hunt in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 2nd, 2011, 02:33 PM
  3. Whirlpool ultimate care II washer seems to drain while filling
    By foghornbeast in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 29th, 2010, 12:32 PM
  4. Whirlpool Ultimate Care II washer - no drain or spin
    By emmittbarks in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 19th, 2008, 10:44 PM
  5. whirlpool ultimate care 2 washer
    By mamapiglet1960 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 6th, 2007, 07:44 PM
