Results 1 to 10 of 17
Thread: Maytag refrigerator not cooling model MTB2156BEW
    Apr 2005
    Post imported post
    I have a Maytag refrigerator model MTB2156BEW. It does not cool either freezer or food compartment. The fan is working but it blows only warm air. I'm an old tv serviceman so I can make voltage and resistance checks if I knew where to look. Thanks in advance for any help. Al
    Oct 2004
    Post imported post
    **It does not cool either freezer or food compartment. The fan is working but it blows only warm air.**
    Is the compressor running? Is the condnesor fan motor ( beside the compressor ) running? Any frost on the freezer back wall?
    http://www.applianceaid.com/
    Appliance Repair Aid
    Apr 2005
    Post imported post
    Hi Jeff
    No the compressor is not running
    Yes the condenser fan motor is running
    Al
    Oct 2004
    Post imported post
    Evaporator fan motor running, condensor fan motor running should = cold control and defrost timer are sending power ok....problem in the compressor or the overload/start relay.
    Have seen a couple of "open" ( no continuity ) overloads. The relay, overload and compressor can be ohmed for continuity.
    Some stuff that may help...
    http://www.applianceaid.com/refrigerator.html#clicking
    Wire diagram if needed
    Apr 2005
    Post imported post
    Hi Jeff
    How do you guys do it,working on these things every day.laying on the floor, working in a cramped area, I'm starting to appreciate appliance repairmen more now.Anyhow I took off a cover that is on the compressor and found what looks like relay switches, after removing the connectors I measured ohms across 3 terminals and found very low ohms,about 4 ohms, seems low for a compressor. By now I figured let somebody that knows what they are doing look at it,so I put everything back together and closed it up. Just to check I plugged it in and turned it on. There was an arcing noise momentarily and the unit started working normally,even made icecubes. After it was cold enough it shut off,then when it came back on again-you guessed it- just warm air again.Does this sound like bad or intermittent relays or bad winding in the compressor? I won't bother you with this problem again- It might be time to call my sears service co. Thanks for your time
    Al
    Oct 2004
    Post imported post
    althis wrote:
    After it was cold enough it shut off, then when it came back on again -you guessed it- just warm air again.
    Which "came back on again"? The fans, the compressor??
    If the compressor did not come back on again when the fans, etc. did, it could just be a problem in the compressor's relay or overload protector or in the compressor itself.
    If in the compressor, the part itself should be covered by a warranty for 5-years from date of purchase although the labour to replace it ($$$+) would not usually be (see the following link).
    LINK > Appliance411 : Limited Warranties
    JFYI
    Appliance411.com
    =D~~~~~~
    Oct 2004
    Post imported post
    **After it was cold enough it shut off,then when it came back on again-you guessed it- just warm air again**
    Possible both
    Compressor will likely be amp meter tested to make sure it is not drawing too much current which in turn can/could damage the relay and overload.
    Apr 2005
    Post imported post
    Our 18 mo Maytag MTB2156GES just blew on Sunday. A repairperson diagnosed the problem this afternoon as bad relay on compressor. Googled and hit on this thread.
    Is this a common problem for this refrigerator? It's going to put us back $175 in labor and parts (not to mention what $$ wasted on spoilt food); should we order a couple of spare so we can repair it ourselves in the future?? Does this put undue strain on compressor?
    Repair person did some hand waving about not vaccuming coils and not enough clearance around the unit. However, manual specifically states *not* to clean the coils and the space around unit meets specs in manual. Any suggestions to prevent future failures?
    Much obliged for your advice!
    Post imported post
    Its kinda rare to see a relay on the compressor to go out on these maytags.
    The compressor is not running at all?
    All the fans working?
    Frost build up on the freezer back panel?
    The most i see go wrong with these are the defrost board.
    As far as cleaning the condenser, you are right, all maytags have a self-cleaning condenser from 1999-present. I myself own a 1999 freezer on top maytag refrigerator, and i have never cleaned the condenser since it was brand new in 1999.
    Apr 2005
    Post imported post
    Thanks for speedy reply!
    • Fans are working.
    • Can hear compressor come on, but then clicks off again. Tested it w voltmeter and seems fine.
    • Affirmative frost on panel (according to repairperson). Water dripping all night,running down refrig door gasket and pooling on floor.
    Repairperson commented that compressor was 'hot' so I'm worried that there's something wrong wunit or installcausing relay to fail. Any thoughts? Just a bad part?
  1. FIXED: Maytag Refrigerator Model MSD2756DEB is not cooling properly
    By suk in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 23rd, 2011, 09:21 AM
  2. i have a maytag model MZD2766GEB fridge not cooling
    By nubsy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 28th, 2007, 11:30 AM
  3. Maytag PTB195LGRW not cooling
    By rocksguy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2006, 11:36 AM
  4. Maytag Model MSD2732GRQ clicking noise/not cooling properly
    By nova817 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 26th, 2005, 06:01 AM
  5. Maytag Refrigerator - Model PTB2154GRW - not cooling
    By kpd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 6th, 2005, 12:12 AM
