Results 1 to 7 of 7
Thread: Oven doesn't work (broiler does)
    Apr 2012
    Michigan
    Default Oven doesn't work (broiler does)
    Model Number: 790.78624405
    Oven doesn't light/heat up, all else works (including broiler)
    I can see the glow in the back of the oven, but it never ignites
    You will need a new oven igniter. There is a video once you click the link to the part to change it out.
    Here's the oven igniter for your model, you can order it here:
    Manufacturer part number 316489400 is RepairClinic item number 1197384
    316489400
    Apr 2012
    Michigan
    Default Thanks
    Thought it was that
    I have a little problem, unsure how to proceed
    One of the little screw/bolt that holds the ignitor to the bracket seems stripped, it goes around and around and doesn't back out. I have tried a screwdriver under the head of it while I try to back it out, but that hasn't worked.
    Any advice or tips would be appreciated!
    Apr 2012
    Michigan
    Got it out - but the little bolt is shot (threads a mess)
    Ahh yes, I've had that happen many times myself when trying to remove the old ignitor, some I had to cut that bolt off.
    You can go to your local hardware store with the other bolt and they can match it up for you.
    Apr 2012
    Michigan
    Thanks for all your help
    Just wondering, a couple of my knobs for this range have lost their little metal insert that holds them on. Quite useless without them. I have not been able to find just the metal inserts and the original knobs are pretty expensive. Do you know where I could find these metal inserts ??
    Try the hardware store, or go to your local appliance repair shop and the may have some that match.
    If still unable to find them, Here's the lowest price I found on those knobs:
    OEM Part 316218402 KNOB
  1. Replies: 6
    Last Post: December 1st, 2011, 11:28 PM
  2. Frigidaire Oven / Broiler don't work
    By snoughnut in forum Frigidaire/Tappan/Electrolux
    Last Post: September 14th, 2011, 10:02 PM
  3. Oven, Broiler, Self clean, and Oven Light does not work
    By mtim55 in forum Frigidaire/Tappan/Electrolux
    Last Post: April 21st, 2011, 05:02 PM
  4. Replies: 8
    Last Post: December 14th, 2010, 08:55 PM
  5. [FIXED] Oven and broiler won't work
    By 4Axiom in forum GE/Hotpoint
    Last Post: December 7th, 2010, 09:00 PM
