Results 1 to 4 of 4
Thread: 4E code on Samsung dishwasher
    Jun 2012
    florida
    Default 4E code on Samsung dishwasher
    Model Number: DMR78AHS
    Brand: Samsung
    I have a 2 year old Samsung dishwasher model DMR78AHS. A 4E code appeared indicting a water problem. A repair tech replaced the water valve and new hoses. There is plenty of water pressure and the water valve is open and the hoses are not kinked. Still get the error code. I saw a suggestion that the insulation in the door could corrode the wires, took the door off and everything looked fine. Looking for any suggestions as to what to do next.
    Oct 2004
    I have no experience with these but I found this...
Size:  3.0 KB Flow sensor/meter manufacturer Number DD32-00004A
    4E or low flow errorDishwashers
    were produced with an incorrect water flow meter. The water flow meteror impeller controls the amount of water insidethe tub assembly. Specifically, the flow meteraxle shaft was designed to have a 2.5 mmclearance width. The axle shaft was changed to1.5 mm spacing in error. The smaller gapcauses the impeller to touch the base of the housing, restricting water flow. The problem is more
    pronounced where the water pressure is lower.
    SYMPTOM: Depending on the water pressure the symptom the unit will show error code 4E,indicating the water level in the tub is too low. This will occur on the first operation in low water
    pressure environments. In high water pressure installations, the 4E error may be intermittent.
    Solution – The repair for this issue is to replace the entire flow meter assembly which includes the
    impeller and the impeller housing.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jun 2012
    florida
    Thank you Jeff for your help and reply. I will pass this information on to my repairman.
    Oct 2004
    Your welcome, hope it helps
  1. Samsung Dishwasher error code 5E or SE
    By trigger in forum Dishwashers
    Last Post: January 2nd, 2015, 06:42 AM
  2. Samsung Dishwasher 5E error code
    By thewoodenboatguy in forum Dishwashers
    Last Post: January 1st, 2015, 09:29 PM
  3. Error code 5e (SE) on samsung microwave
    By kmivens in forum Samsung
    Last Post: August 19th, 2014, 09:27 PM
  4. Samsung Dryer Error Code AE
    By RHawk in forum Dryers
    Last Post: January 16th, 2014, 08:46 AM
  5. samsung fault code
    By larry harding in forum Samsung
    Last Post: August 29th, 2008, 06:23 AM
