Results 1 to 4 of 4
Thread: KitchenAid - Ice maker not dispensing ice
    Jul 2012
    DFW, Texas
    Default KitchenAid - Ice maker not dispensing ice
    Model Number: KSRA25ILWH03
    Brand: KitchenAid
    Hi. I checked the forum and didn't find an exact match to my problem. If its a re-post, sorry...
    The ice maker is making ice, but when pressing the lever to dispense the ice, nothing. No sounds other than the flap opening up. It quit working after quite a bit of ice melted in the bucket and drained out. I'm not sure if that is the cause or not, but thought I'd mention it. If curious, the ice melted while I was replacing another part that kept the compressor from running.
    From what I could research in the forums, it sounds like the problem could be either the auger motor or the circuit board. Also, all of the lights / switches work on the front of the door (lock / unlock, crushed / cubes, light on / off).
    Any insight on which part needs to be replaced would be helpful.
    Thanks.
    For the ice dispenser problem, Sounds like the plastic pins thats on the water/ice dispenser support have broken.
    You would need to unscrew the 2 screws#26 from the bottom of your front dispenser frame#21 here:
    http://click.linksynergy.com/fs-bin/...a25ilwh03.html
    Then look at your support bracket#15 to see if the little plastic pins are broken that hold your ice and water dispenser switches in place#14.
    Here is the one for your model, in case you need to order it:
    Manufacturer part number 2180226 is RepairClinic item number 449582
    2180226
    Jul 2012
    DFW, Texas
    Hi Jake. Sorry for the delay in responding, I was finally able to get the ice dispenser disassembled to check the plastic pins. The plastic frame and pins looked fine. The levers made good contact with the switches and they didn't flex or move. Also, I checked the connections to the various switches, etc., nothing loose or any corrosion found.
    I appears that everything, except the motor that turns the ice agitator arm, is working correctly.
    What would you suggest I check next to diagnose the problem?
    Thanks.
    Then your ice dispenser motor is bad.
    Here's the ice dispenser motor for your model you can order here:
    Manufacturer's Number: 2188869
    To get to that motor just remove 2 screws#35 and then the cover#33 comes off. It should be located under the liner part that the ice bucket sits on.
  1. Replies: 3
    Last Post: September 15th, 2010, 01:02 AM
  2. Replies: 3
    Last Post: March 28th, 2008, 10:54 AM
  3. KitchenAid KBRO36FTX icemaker won't make ice
    By 06bexc in forum KitchenAid
    Last Post: October 24th, 2007, 10:56 AM
  4. Maytag dispensing water but wont make ice!
    By moshe and tzippy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2007, 12:06 PM
  5. Help! Ice Make Won't Stop Dispensing!
    By AStein12 in forum Sears Kenmore
    Last Post: September 20th, 2006, 09:49 PM
