Results 1 to 10 of 17
Thread: LG DLEC855R tE3 error
    Jul 2012
    Portland
    Default LG DLEC855R tE3 error
    Model Number: DLEC855R
    Brand: LG
    I'm helping a friend out who is having issues with her LG electric dryer. The dryer will run for about 3 minutes, (it will not heat), and then shut off with a tE3 error code. I've been told this error is a thermistor error so I connected my multi meter up the the thermistor connector and got 11 ohms at room temperature. I read somewhere that the thermistors rarely malfunction and if you have about 11 ohms of resistance it is good and more than likely the circuit board is bad. I replaced the circuit board but am still getting the tE3 error.
    While I was checking the unit out I did find a sock wedged under the lint screen, it looked like it had been there for a while, so I'm assuming this caused the dryer to overload somewhere but not sure where else to turn to.
    Any suggestions?
    Oct 2004
    Not sure if this helps, found this...a copy:
    'TE1' error code - Heating Error - Low temperature thermistor open circuit
    'TE2' error code - Heating Error - Low temperature thermistor short circuit
    'TE3' error code - Heating Error - High temperature thermistor open circuit
    'TE4' error code - Heating Error - High temperature thermistor short circuit
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jul 2012
    Portland
    Thanks for the quick reply. You don't happen to have a link for a service manual or a schematic where the high thermistor is located do you? I tried a search and couldn't find one.
    Oct 2004
    DLEC855R
    That won't come up for me. I got DLEC855W to work for me.
    D210 is a thermostat Click image for larger version.
    B135 says thermistor Click image for larger version.
    Thermistor,ntc Manufacturer Number 6323EL2001C
    Thermostat assembly Manufacturer Number 6931EL3001D
    Jul 2012
    Portland
    Thanks for the diagram Jeff. The W and R at the end just means white or red. It must be the thermostat that's bad because the thermistor checks out OK. I'll check it out.
    Oct 2004
    Let us know what you find/see....thermistors can be intermittant as well!
    Jun 2011
    Danville, California
    Don't be surprised if replacing the thermistor doesn't solve the problem. I had a brand new LG dryer unit give me a te1 and te3 intermittently. Found it to be a bad wire harness. Replaced the harness and everything was good to go.
    Appliance Repair Tech
    LG Authorized Servicer
    Oct 2004
    Intermittant problem are the worst!!
    Jul 2012
    Portland
    Got it fixed.
    It was the high thermostat, the one in the back, fortunately it was a thermostat with a reset switch so I just had to push the switch and the dryer was up and running again.
    Thanks for all the help, it is greatly appreciated!
    Oct 2004
    Thankx for the update, glad all is well again
  1. Cabrio oL error and F51 error.. Tried everything. Still not fixed
    By ChrisBinSLC in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 16th, 2012, 02:57 AM
  2. Replies: 3
    Last Post: November 1st, 2010, 01:25 AM
  3. Kenmore Elite F02 error and SUDS error
    By mfrazer34 in forum Sears Kenmore
    Last Post: July 12th, 2007, 01:17 PM
