Results 1 to 4 of 4
Thread: Maytag MBR2258XES1 leaking water on floor, ice on bottom of freezer
    Aug 2012
    Birmingham, AL
    Default Maytag MBR2258XES1 leaking water on floor, ice on bottom of freezer
    Model Number: MBR2258XES1
    Brand: Maytag
    I have a Maytag fridge with freezer on the bottom (Model MBR2258XES1). I have been finding puddles of water on the floor beneath the corners of the freezer and there is a sheet of ice on the bottom of the freezer. I have seen the water coming out of the freezer a few times--it seems to originate from the back wall of the freezer
    I read several other threads with the same problem on other models but am not sure where the drain is in this model, or how/if the back of the freezer can be removed.
    Thanks for any assistance!
    Jul 2006
    You'll have to remove any ice maker and freezer shelves. The center air vent will un-clip from the back wall then remove the back wall. From there you can access the drain hole. Unplug the machine and use a hair dryer to melt all the ice out. Run very hot water down it to clean it out.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Dec 2012
    Minnesota
    Rick, I have the same problem in my Maytag model RSW25E0D. The back wall is secured with 8 screws. I have been told the drain line is clogged. I would prefer to access the line from inside the unit as the refrigerator is very tightly squeezed under a cupboard and next to a cabinet. Is it as simple as removing the panel and accessing the drain line?
    Jul 2006
    Gregg, I can't get anything to come up with that model number. Can you recheck it. Read it from the tag on the machine. Click here then follow the link “Help me find my model number” Appliance Parts at RepairClinic. 125 Brands. 365 Day Returns.
  1. FIXED: Maytag French door bottom freezer leaking water
    By rgall5 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 5th, 2016, 01:12 PM
  2. FIXED: Maytag freezer has thin layer of ice on bottom and water on floor
    By Frederick in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 21st, 2015, 07:18 AM
  3. FIXED: Maytag freezer leaking onto floor, ice on bottom
    By agd2002 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 1st, 2013, 08:37 PM
  4. Maytag freezer leaking onto floor, ice on bottom
    By dunzer in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 23rd, 2012, 03:58 PM
  5. Replies: 8
    Last Post: October 6th, 2011, 01:17 PM
