Results 1 to 8 of 8
Thread: Wiring schematic for Maytag SDE515DAYW ?
    Aug 2012
    Sparks, Nevada, United States
    Default Wiring schematic for Maytag SDE515DAYW ?
    Model Number: SDE515DAYW
    Brand: Maytag
    Hi, Does anyone have a Wiring schematic for Maytag - SDE515DAYW? (Series 12) I am in the process of going through
    the entire dryer and could really use a wiring diagram that I can print.
    Thank you.
    Dave
    Oct 2004
    See attached.
    Attached Files Attached Files
    http://www.applianceaid.com/
    Appliance Repair Aid
    Aug 2012
    Thank you very much for your expeditious reply Jeff! The information
    contained in the pdf file is excellent and will save me a ton of time.
    Thanks again.
    Dave
    Oct 2004
    Your welcome!
    Aug 2012
    The original problem was no heat. I have cleaned up entire area and especially the area below lint screen was packed with lint. I have tested all the thermostats and heating element and they all appear to be ok. Is it possible for the dryer to stop heating without blowing a fuse or thermostat? I want to make sure I have checked everything before putting it all back together.
    Thank you!
    Dave
    Oct 2004
    Sure.
    A copy:
    Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
    A- Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
    Checked for power to the unit yet?
    220-240 volts AC from red to black, 110-120 volts AC from red or black to white.
    Aug 2012
    Hi Jeff, I have been out of town. Back to work in the dryer this weekend. I will check the
    items you indicated in your last response. Thank you.
    Oct 2004
    If you get a chance, let us know what you find/see.
  1. Maytag SDE515DAYW Must Hold Down Start Button to Keep it Going
    By lind777 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 18th, 2012, 05:35 PM
  2. Need a wiring schematic for this unit
    By wildimaginations in forum Frigidaire/Electrolux
    Last Post: August 4th, 2011, 11:05 AM
  3. Wiring schematic Mod. DNCD450AEOWC
    By JACKSPRAT in forum GE/Hotpoint
    Last Post: December 7th, 2007, 11:14 AM
  4. Need wiring schematic
    By slls in forum Sears Kenmore
    Last Post: November 17th, 2006, 02:24 PM
  5. Need wiring schematic for TBF16SBF
    By bogreen in forum GE/Hotpoint
    Last Post: February 12th, 2006, 06:35 AM
