Results 1 to 5 of 5
Thread: Kenmore fridge ice & water dispenser not working
    Aug 2012
    Florida
    Default Kenmore fridge ice & water dispenser not working
    Model Number: 795.78512800
    I have a freezer on the bottom and fridge on top fridge with water and ice dispenser in the door. The display has gone dark and water and ice dispenser have stopped working. Everything else is working properly. Seems as though there is a power/computer issue. Interetingly just pior to this happening the ice flapper would flutter open and closed repeatedly the we shut the door. It may be unrelated. But now it doesn't do it anymore now that the whole display stopped working. Any ideas. Thanks in advance.
    Jul 2006
    Remove the top hinge cover and check all the wire connections. Sometimes disconnecting the connector several times will do the trick.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Aug 2012
    Florida
    Thank you for the response. I removed the hinge cover, unplugged and replugged them all multiple times in hopes of cleaning a connection. The open door sensor button works as does the little light that comes on when you fill a glass of water. It is on except when I unplug the connection. The water & ice dispenser still don't work along with the electronic display. Any other suggestion? Thanks in advance
    Jul 2006
    I haven't worked on very many of these LG models. wildimagination is a LG tech. He might know.
    Jun 2011
    Danville, California
    Uh-oh!!! I've seen this problem and it's a wire harness problem inside the door panel. Something shorted inside. Try this first, remove the funnel assembly by pulling straight down. Now look at the bottom of the display panel and you'll find pry holes to unsnap the panel from the door frame. Unsnapping will sound like youre breaking something but just continue to remove the panel. Look at the connector to the display board to make sure it's properly connected. If it's ok, then you have a bad door wire harness and the door has to be replaced.
    Hope it's not the door.
    Appliance Repair Tech
    LG Authorized Servicer
  1. Replies: 9
    Last Post: February 13th, 2012, 07:33 PM
  2. Replies: 2
    Last Post: July 8th, 2011, 10:50 AM
  3. Amana fridge water dispenser stops working
    By lanczar in forum Amana
    Last Post: June 7th, 2011, 02:02 AM
  4. Kenmore fridge water dispenser not working
    By sarickard in forum Sears Kenmore
    Last Post: February 1st, 2009, 05:30 PM
  5. New Maytag Fridge, water dispenser not working.
    By minskore in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 29th, 2006, 10:09 PM
