Results 1 to 6 of 6
Thread: Whirlpool Dryer not getting hot
    Jan 2012
    spring
    Default Whirlpool Dryer not getting hot
    Model Number: WED5550SQ0
    Dryer runs but produces no heat.
    I pulled the element and performed a continuity test. I'm getting 10ohms of resistance from the element.
    Oct 2004
    A copy:
    Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?A- Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
    A ohm meter test for these parts is here.
    Element sounds like it ohmed ok, as long as no breaks in the element it is ok.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jan 2012
    spring
    ok I think it is this..
    High Limit Thermostat
    Manufacturer Number 3977767 Item #898078
    I get no change on my multimeter set to 200 ohms.
    Oct 2004
    Join the two wires together as a test.
    Might want to consider upgrading the whole safety kit...it is only a little more...
    Attachment 6588 Heating element thermal cut-off (thermal fuse) 309 degrees and high-limit thermostat 250 degrees, with wiring kit Manufacturer Number 279816
    Jan 2012
    spring
    Quote Originally Posted by jeff1 View Post
    Ok I connected the red wire that attached to the little blade on the high limit thermostat leaving off the white wire/black line (what is it for?). The heating element came on. So I guess that is it. So you recommend replacing the other two thermostats in addition to the high limit thermostat?
    Just as a point of curiosity (the wife asked)... can she run her load of laundry that is currently wet hanging all over our house? :-) I'm guessing no.
    Oct 2004
    It is an updated kit...that is the one we use....your choice.
    While it would be good to get some laundry caught up, it is not a good idea to run it with a safety device bypassed.....I would get something needed done but stay in the same room to be safe.
  1. Replies: 3
    Last Post: June 16th, 2012, 01:43 PM
  2. Whirlpool Dryer Ultimate Care dryer ii will not start. No ticking.... nothing.
    By kathlinemary in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 1st, 2012, 01:01 AM
  3. Whirlpool gas dryer making squeeky noise and won't dryer clothes completely
    By jpeguero in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 14th, 2012, 12:50 PM
  4. Whirlpool Dryer - Cabinet light always on,dryer will not turn on
    By dehbum in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 1st, 2011, 10:01 PM
  5. Replies: 4
    Last Post: April 24th, 2006, 03:36 AM
