Results 1 to 4 of 4
Thread: LAT2300AAE Vibration issue
    Mar 2006
    California
    Default LAT2300AAE Vibration issue
    Hello:
    I have a Maytag Performa LAT2300AAE that exhibits violent vibration in the spin cycle; it wants to walk across the floor; but not all the time.
    Seems that if I run it with no laundry in it at all it operates fairly normally.
    With a load there seems to be a noise during the spin cycle coming from the right rear top side (facing the front of the washer) , as though something were hitting against the inside wall of the washer and as the spin cycle advances the noise and vibration get scary.
    I've seen references in these forums to snubbers, dampeners, (dampers?) and issues with brake assemblies; all these seem related to noise and vibration issues with these machines.
    What should I be looking for here? What are the tests to isolate the problem(s)?
    Any help is much appreciated
    Dan
    Sounds like a snubber problem, if you tilt your washer back and look underneath it, if you see white plastic shavings, then your snubber is going bad.
    Heres some links about it:
    http://www.applianceblog.com/mainforums/showthread.php?t=3152&highlight=snubber
    http://www.applianceblog.com/mainforums/showthread.php?t=1732&highlight=snubber
    Mar 2006
    California
    Default My update
    Quote Originally Posted by Jake
    Thanks for the reply: I don't see any plastic shavings either on the underside of the washer or on the floor below it.
    Even though you don't see any shavings, it could still be bad unfortunately.
  1. GU1500XTLQ2 water circulation issue
    By kabozek in forum Whirlpool/Roper/Estate
    Last Post: March 21st, 2007, 01:11 AM
  2. Maytag Neptune Control Board Issue
    By tim205 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 17th, 2007, 11:46 PM
  3. Intermittent Filling Issue - GE Profile
    By mikeswaggs in forum GE/Hotpoint
    Last Post: July 10th, 2006, 09:49 PM
  4. Amana side-by-side filtered water flow issue
    By Steel_Cranium in forum Amana
    Last Post: April 21st, 2006, 04:19 PM
  5. Kenmore vibration 90 series 110.68932491
    By wsdc in forum Sears Kenmore
    Last Post: March 24th, 2006, 12:35 PM
