Results 1 to 4 of 4
Thread: Kenmore Washer slow to spin up
    Oct 2007
    FT Worth, TX
    Question Kenmore Washer slow to spin up
    Model Number: 110.20922990
    Age: More than 10 years
    The age is a guess. I have a Kenmore washer with a strange problem. It washes fine. It runs through the wash cycle with no problems. Then on the rinse cycle it will pump the water out and when it tries to get into the spin cycle it has problems. It seems to be spinning at half speed and is making an almost constant clicking noise. Sort of like a relay clicking in and out. Then eventually it clicks one last time and spins up like it should. Once it spins up, it will spin up the next time if I stop it and then restart it. It only happens in the rinse cycle. I am at a loss as to what it is and why it only happens in the rinse cycle and not in the wash cycle.
    As always, any assistance is greatly appreciated.
    Jul 2006
    It's most likely the brake cam driver on the bottom of the spin tube. The white piece in this picture:
Name:	Whirlpool Basket Drive Cam.jpg
    Here it is off the spin tube and how it sits in the clutch. It's probably worn down and hitting the clutch spring then skipping over it until it makes contact
Name:	Whirlpool Clutch.jpg
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Oct 2007
    FT Worth, TX
    Thanks for the quick reply Rick. I just happen to have one of those hanging around so I'll swap it out tomorrow and see if it helps. I'll let you know how it turns out.
    Jul 2006
    OK, sounds good
  1. ESTATE Washer noise and slow spin in spin cycle
    By Chaparral216 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 25th, 2012, 12:54 PM
  2. Whirlpool Washer slow spin and wet clothes
    By Trying2fixit in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 15th, 2010, 11:41 PM
  3. Kenmore Series 80 Washer slow spin
    By jjenkins in forum Sears Kenmore
    Last Post: December 15th, 2006, 11:21 PM
  4. Kenmore 70 slow agitate, no drum spin
    By dmilobar in forum Sears Kenmore
    Last Post: March 12th, 2006, 01:17 PM
  5. Whirlpool Washer - Slow Spin Wet Clothes
    By soggypants in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 15th, 2006, 01:50 PM
