Results 1 to 10 of 11
Thread: Kenmore Washer Agitates But Does Not Spin
    Aug 2006
    Milwaukee Wisconsin
    Default Kenmore Washer Agitates But Does Not Spin
    Model Number: 110.92588210
    Age: More than 10 years
    Our Sears Kenmore 110.92588210 washer was purchased new in 1996. A few days ago we noticed the agitator still works but the basket no longer spins - the washed items never spin dry.
    I saw from other posts on this forum where people described a similar problem, and that a clutch and basket drive kit was recommended to repair the washer. Would that be the case for me, too? Is there a need and/or method for me to diagnose the problem further?
    Also, if the above parts are recommended as the fix, what would be realistic expectations as far as this washer's future reliability. So far all it has needed in the past has been a couple of timers. But now, after 16 years of use, should I be thinking about replacement rather than repair?
    Thanks in advance for any ideas on this.
    Aug 2006
    Milwaukee Wisconsin
    Also, after looking at the parts for this machine, if I were to fix it, would I need the Clutch Assembly or the Clutch Band Kit, or both?
    Now after the wash cycle does it drain fine and the motor keeps running but just not spinning? Or the motor does not run thus no spinning?
    Aug 2006
    Milwaukee Wisconsin
    It draina fine after the wash cycle and it does seem like the motor is spinning.
    OK, Then if its dead silent after it drains and the timer won't go any further, then it sounds more like your lid switch is bad.
    When you close your lid, do you hear a click sound just before it shuts?
    Here's the lid switch for your model:
    Manufacturer part number 285671 is RepairClinic item number 2927
    This video shows how to test your lid switch for continuity:
    This video shows how to access/change the lid switch:
    Aug 2006
    Milwaukee Wisconsin
    I think I may have miscommunicated in my previous post.
    The timer progresses through all steps in the wash and rinse cycles
    The motor continues to run after the tub has been pumped dry
    The only thing that does not seem to be happening is any spinning action of the tub during and after the draining of the tub
    Oh ok, I thought you said no sound was present after the drain.
    If you hear the motor still running but not spinning, Yes, sounds like the clutch or the basket drive, most of the time its just the clutch though.
    Here is your clutch assembly for your model you can order here:
    Manufacturer part number 285785 is RepairClinic item number 2670
    285785
    Here's a help video for replacing the clutch:
    Aug 2006
    Milwaukee Wisconsin
    Thanks - I ordered the part you suggested.
    Ok sounds good, keep us posted.
    Aug 2006
    Milwaukee Wisconsin
    Thanks for the guidance Jake. I installed the replacement clutch today - the washer tub spins again. I appreciate your help on this.
  1. Replies: 3
    Last Post: June 13th, 2012, 06:08 AM
  2. Washer agitates but wont drain or spin
    By foottpp in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 20th, 2012, 08:46 AM
  3. Whirlpool Washer Agitates, won't spin and makes noise
    By Jan123 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 27th, 2011, 12:11 PM
  4. Kenmore washer agitates but will not spin, why?
    By theking4u in forum Sears Kenmore
    Last Post: March 3rd, 2011, 08:28 PM
  5. Replies: 1
    Last Post: June 15th, 2010, 12:36 AM
Tags for this Thread
