Results 1 to 8 of 8
Thread: Maytag Centennial Washer noise
    Feb 2012
    Georgia
    Default Maytag Centennial Washer noise
    Model Number: MVWC300XW1
    Brand: Maytag
    Just thought I'd share. My Maytag Centennial washer was making a loud noise that sounded a lot like gears grinding when the washer was sensing the load, agitating, or spinning. It was not constant, but very loud and expensive sounding. I leaned the washer back and noticed the plastic cage around the pulleys was cut in a perfect circle that matched the large pulley under the drum. Long story short, the nut that holds the drum pulley on had come of and allowed the pulley to drop causing the noise. Put the nut on and tightened it up. Problem solved. Hope this helps someone.
    We need full the model number. So it can help others.
    Click here: Appliance Parts at RepairClinic. 125 Brands. 365 Day Returns.
    Then you will see a link that says: Help me find my model number.
    Nov 2012
    louisiana
    Thanks for the info, my Maytag 700xl had the same issue. When I looked under the washing machine, there was a bolt that fell off! Tightened it up and its good as new! Thanks for the help!
    Regards,
    Bryan
    Mar 2013
    indianapolis
    Cool OMG lifesaver...
    Thanks so much...i couldn't stand this noise my maytag centennial was making..so much I would only run it when i left. I did this simple trick and I can't even hear it now...my kids are thankful too
    May 2013
    United States
    Thank you for your post!!! My Maytag Centennial washer "MVWC300XW1" was doing the same thing. I took off the back panel and found the belt pulley dipped and was rubbing through the guard.
    I tightened the nut about 3/4 of a turn and it straightened back up and the noise was gone
    Seems we are having a rash of these nuts coming off or coming loose.
    So if that nut keeps coming loose or coming off, I'd suggest going to your local hardware store and buy and apply loctite blue 242 threadlocker and re-tighten that nut to keep it from loosening up again.
    Here it is: Threadlockers from Loctite Products | Threadlocking / Mechanical Gasketing | Loctite Adhesives
    Here's the Splutch assembly with transmission drive pulley for these models:
    Drive Pulley W10315818 Order now for same day shipping. 365 day return policy. RepairClinic.com
    This video shows the belt guard, belt, transmission pulley and nut:
    Jul 2013
    Wind Gap PA
    As this image (from Jdan) shows - My Maytag washer was also making a loud noise that sounded a lot like gears grinding when the washer was sensing the load, agitating, or spinning. I leaned the washer back and noticed the plastic cage around the pulleys was scrapped in a perfect circle that matched the large pulley under the drum. However, the nut on my washer is peened and cannot be tightened or loosened (even with an 18" wrench). Unfortunately, the mechanism seems to wobble (as if the nut needed tightened). I'd like to provide a few choice words to the engineer who thought the belt would stay in place after only 2 years - without a built-in circumference guard on the plastic wheel. The outer plastic cover for the wheel is being chewed-up by the belt, as it tries to come off.
    I guess I have to call a repairman. But I am going to be extremely unsatisfied if there is not a fix in place to prevent this from re-occurring. I know this is not a member issue, but I'd appreciate a contact in Maytag that understands this potential manufacturer's defect. They've GOT to be kidding! I'll check back and let members know the cost of the repair.
    Jan 2014
    Florida
    As everyone else my washer had the same issue....The sound was horrible. The belt had eaten away the plastic case. Tightened the screw and now washing cloths in peace and quite.Thank you for the info
  1. Maytag Centennial making loud screeching noise
    By Carol Armstrong Alvarez in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 20th, 2012, 11:14 AM
  2. Maytag Centennial Dryer, too hot
    By channel rat in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 19th, 2012, 08:07 AM
  3. maytag centennial washer won't agitate
    By Handy Bob in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 20th, 2011, 10:49 AM
  4. Maytag® Centennial® Top-Load Washer and Dryers ????
    By Aahhyes68 in forum Maytag/Jenn-Air Reviews
    Last Post: May 24th, 2010, 07:27 AM
  5. Maytag Centennial
    By mddesign in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 22nd, 2007, 04:06 PM
