Results 1 to 3 of 3
Thread: No heat - Kenmore Oasis Dryer
    Oct 2012
    Tacoma, Washington
    Default No heat - Kenmore Oasis Dryer
    Model Number: 110.67042600
    So my Kenmore Oasis dryer will run, but will not dry clothes as there is no heat. First thing that I need is a tech sheet. I have removed the control panel and there is nothing underneath so I am running blind at this point. I have tested the power to the unit and it is 220.
    Hi David,
    The tech. data sheet should be inside the bottom of your dryer.
    1. Unplug dryer or disconnect power.
    2. Open the door.
    3. Push on the retaining clips located under top of
    dryer on the right and left side using a flat object
    such as a putty knife.
    4. Slowly rotate top backward and lean against wall,
    or support with a prop rod.
    5. Disconnect the door switch wire harness located
    on the right side.
    6. Remove the front panel/door assembly by
    removing the two front cover screws at the top
    of the panel inside the cabinet, and lifting upward.
    7. Disconnect the moisture sensor connections.
    8. Remove the lint screen.
    9. Remove the lint screen housing by removing the
    four screws holding the lint screen housing.
    10. Remove the front bulkhead by loosening the
    upper two screws and removing the lower two
    Then you have access to your thermal cut-off, high limit thermostat, heater, blower wheel housing, and the thermal fuse.
    First check your thermal cut-off and high limit thermostat its #47 and #48 here:
    Here's the thermal cut-off kit for your model you can order here if needed(Part testing videos included in this link):
    Thermal Cut Out Fuse Kit 280148 Order now for same day shipping. 365 day return policy.
    If both read fine, then ohm test your heater.
    Watch this video:
    Here's the heating element for your model if you need to order it:
    Whirlpool 8544771 Heating Element
    Oct 2012
    Tacoma, Washington
    Hey Jake,
    thanks for the information. I will keep you updated as to what I find.
  1. FIXED: Kenmore Oasis Elite no heat?
    By rh455 in forum Sears Kenmore
    Last Post: July 16th, 2014, 10:44 AM
  2. Kenmore Elite Oasis Electric Dryer - No Heat
    By brianh in forum Sears Kenmore
    Last Post: December 15th, 2011, 06:11 PM
  3. Kenmore Elite Oasis- propane- no heat
    By Badburn in forum Sears Kenmore
    Last Post: July 8th, 2011, 03:25 PM
  4. [FIXED] Kenmore Elite Oasis - No heat
    By defoe91 in forum Sears Kenmore
    Last Post: September 9th, 2010, 10:16 PM
  5. Kenmore Elite Oasis 110.6703 Electric Dryer - No Heat
    By soldenka in forum Sears Kenmore
    Last Post: October 17th, 2009, 01:40 PM
