Results 1 to 10 of 11
Thread: Maytag QuietSeries 200 won't start or even turn on
    Nov 2012
    Toronto
    Default Maytag QuietSeries 200 won't start or even turn on
    Model Number: MDB7751AWS
    Brand: Maytag
    My Maytag quietseries 200 doesn't start or even turn-on. No lights at all when I press Start/Cancel button. I follow
    the repair manual and check the junction box. The repair manual says that at the junction box there should be 105V (minimum)
    but I when I measure it, it has 120V. What could be the problem?
    Jul 2006
    Check the door latch assembly and the two micro-switches. I've seen a broken latch cause that problem or a faulty switch can cause that problem.
    Door Latch W10130695 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2012
    Toronto
    What to check with the door latch? Physically they look good. Any voltage or resistance that I need to check?
    Jul 2006
    Check the micro-switches for continuity with an ohmmeter.
    Nov 2012
    Toronto
    I checked the micro-switches and they're good. When the button is press, no continuity. When the button is not press, there is continuity. Anything else to check?
    Jul 2006
    Quote Originally Posted by chrischay View Post
    You better recheck the switches because if that's really what you measured, they're bad. When the door is latched the micro switch button is pressed in by the latch. When the button is pressed in on the switch, the switch is closed and should show continuity.
    Nov 2012
    Toronto
    The way I checked it is by removing the micro switches from the door latch. After removing them from the door latch, I press the button and no continuity but when the button is not press, there is continuity. They are good both of them. These switches are normally close, meaning it has continuity when the the button is not press.
    Jul 2006
    OK, listen up my friend, If you have the wires on COM and NC on both switches and when the door is closed the buttons on the switch are pressed in, you're not getting any power to the control because like you just said,
    Nov 2012
    Toronto
    Ok let me ask you this, don't think about the door latch. Let's say you have the micro switch on your hands, what is the normal condition of the switch?
    Like I said I removed the micro switch from the door latch (micro switch not attached to the door latch anymore) to isolate the problem and test the continuity.
    Jul 2006
    It depends on where the wires are connected. One wire will be connected to the COM terminal on the switch. There are two more terminals on the switch, NC and NO. Now sometimes on those switches they leave off one terminal if they don't need but it could be either terminal. So look on the switch at the terminals where the wire is connected. If it's NO then the normal condition of the switch is open, no continuity. If the wire is on NC then the normal condition is closed, continuity. Now do you understand the switch has two Normal conditions, NO (Normally Open) and NC (Normally Closed).
  1. Maytag Quietseries 300
    By alcgraham in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 5th, 2011, 12:20 PM
  2. Maytag Dishwasher Start Light Will Not Turn On
    By Geri031706 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 10th, 2011, 01:29 AM
  3. Maytag quietseries 200
    By r1_ryan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 23rd, 2007, 11:50 PM
  4. QuietSeries 100 intermitently won't start
    By slustu in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 22nd, 2007, 05:23 PM
  5. Im new: problem with maytag quietseries 300
    By Eddiegsr in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 11th, 2007, 10:57 AM
