Results 1 to 5 of 5
Thread: Maytag MDB4100 Spray Arm Removal
    Mar 2006
    PA
    Default Maytag MDB4100 Spray Arm Removal
    Does anyone know how to remove the spray arm from a Maytag MDB4100 dishwasher. The spray arm has a plastic insert with slots in it. It does not have a spray tower. The plastic insert moves freely and can be pulled up and turned, but nothing happens when I do that.
    Jim
    Oct 2004
    MDB4100
    That is part of a full model#.
    Lower one?
    Lower, unscrew #34 and lift off the arm assembly....
    Upper, grab the middle of the spray arm and yank down hard.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Mar 2006
    PA
    Default Thanks, that worked
    Thanks Jeff. That worked. There was alot of calcium and lime encrusted on the lower arm that I didn't see that the cap could be removed. It took some effort, but finally the cap moved and I was able to remove the lower spray arm.
    Jim
    Mar 2006
    pennsylvania
    run a cycle with four glasses in upper shelf in upright position, one per corner. With no other dishes in unit, Fill each glass with 8 oz TANG orange drink powder. Let unit run a full cycle. Water will fill glasses during cycle and provide a constant flow of solution. This helps clean up calcium and generally leaves behind a pleasant smell. Cheaper than glisten and works just fine.
    Oct 2004
    That worked
    Great!
    Your welcome!
  1. Frigidaire Gallery D/W FDB949GFS2 Spray Arm Problem
    By kshoemaker4 in forum Frigidaire/Electrolux
    Last Post: April 17th, 2007, 08:07 PM
  2. upper spray arm not moving
    By altaub in forum Sears Kenmore
    Last Post: March 24th, 2007, 01:11 PM
  3. No water to upper spray arm
    By chasw in forum Frigidaire/Electrolux
    Last Post: January 23rd, 2007, 11:13 AM
  4. Replies: 3
    Last Post: December 14th, 2006, 09:23 PM
  5. Spray Arms not Spinning on Maytag MDB9600AWB Dishwasher
    By paulrhodes in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 19th, 2005, 05:52 AM
