Results 1 to 6 of 6
Thread: Need help! Maytag fridge/top freezer w/ ice maker leaking water
    Nov 2012
    texas
    Default Need help! Maytag fridge/top freezer w/ ice maker leaking water
    Model Number: M1BXXGMY00
    Brand: Maytag
    My fridge is just over 1 yr old and the warranty is expired. Of course then we start having problems. Our freezer has been leaking water onto the bottom shelf. Sheets of ice collect and then it starts leaking water out of it. I have cleared it of ice several times and checked all connections. It leaks when ice maker is off and gets worse when it's on. What can I do? Please help as we don't have the money to call someone to repair it.
    Jul 2006
    Ice on the floor of the freezer section or water leaking on floor by the freezer door on a SXS or Bottom Mount or water leaking into the fresh food section on a Top Mount, is an indication of a blocked defrost drain line. Remove the evaporator cover (freezer section back wall). The evaporator sits in a defrost pan with the drain hole located bottom center. Use a hair dryer to defrost the ice over the drain hole and then run very hot water through it to clean it out. A turkey baster works well. Most of the time that will solve the problem.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2012
    texas
    Quote Originally Posted by rickgburton View Post
    Ok so I'm going to try this. I will unplug but do I also need to shut water off before I try this?
    Jul 2006
    No, you don't have to shut the water off but you might have to remove the ice maker to get the evaporator cover off.
    Nov 2012
    texas
    Thanks for your help! It took quite a while for me to get everything figured out. That was the problem. There was an ice plug in the drain and a LOT of ice in that whole area. I melted all the ice and poured water but after a (very) long time, it still wasn't draining. I finally went to check the drip pan under the fridge and found the bottom of the tube that led to it was pinched off and as soon as I moved it, water came out. After that, the water flowed through freely. Thanks again.
    Jul 2006
    Awesome, good job!
  1. Water leaking from freezer turned into a warm freezer/fridge
    By MandyB in forum Frigidaire/Electrolux
    Last Post: January 24th, 2012, 11:54 PM
  2. Replies: 3
    Last Post: October 22nd, 2011, 11:25 PM
  3. Fridge Not Cooling, Freezer Is But Iced Up In Back, Water Leaking Into Fridge
    By mpkeith in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 25th, 2011, 01:51 AM
  4. Freezer leaking a lot of water from ice maker area
    By jatepper in forum GE/Hotpoint
    Last Post: November 24th, 2009, 12:57 AM
  5. Maytag MSD2356AE leaking water in fridge (not drain prob)
    By kfree in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 2nd, 2006, 11:38 PM
