Results 1 to 8 of 8
Thread: Dishwasher stops randomly...green light flashes...sometimes will run...sometimes not
    Dec 2012
    Fishtail, Montana
    Default Dishwasher stops randomly...green light flashes...sometimes will run...sometimes not
    Model Number: KUDP02FRBL0
    Brand: KitchenAid
    OK, my dishwasher will randomly stop during normal and heavy duty cycles, and usually the tub is full of water when it does, and the green light will be flashing. I have tried moving things around, then push the start button again and it will try to start again, but something keeps making it stop! Now if I press cancel it will usually drain the tub, and believe it or not it will run a quick wash cycle with no trouble! I popped the breaker, and the first cycle after that ran great, BUT, the next cycle was back to giving me trouble. I can't figure out what is stopping it (especially when the quick wash will run all the way through). It seems it might be something electrical, but I have no idea where to start. Any direction would be so appreciated!
    Jul 2006
    Which green light is flashing?
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Dec 2012
    Fishtail, Montana
    The light between the start/resume and cancel button...it is green when running and then turns blue to indicate it is done. It flashes when something has interrupted the cycle. And also, today I had it stop on me during a quick cycle...oh no!
    Interesting, Rick there isn't a button for a light in between start/resume and cancel button, could it been a hidden button light for tech. diagnostics?
    Here's his control panel buttons:
    Jul 2006
    Unplug dishwasher or disconnect power. Open console and disconnect the keypad ribbon connection from the control (at P1). Put console back together. Plug in dishwasher or reconnect power. With door latched, disconnect and reconnect thermistor or OWI sensor two times in less than 6 seconds. Wait 10 seconds, and then monitor the control’s response to the thermistor: If the control is OK it will respond by running service diagnostics. Listen for it to begin filling after it concludes the 5–10 second display test at the beginning of the service diagnostics cycle. Check and/or replace the keypad.
    Touchpad and Control Panel 8572497 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Main Control Board W10084141 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Jul 2006
    Twins...lol
    Dec 2012
    Fishtail, Montana
    Yes, that is the control panel on my dishwasher, and though you can't see it, right between the start/resume button and the cancel button is where the light is. It is just a normal light that indicates when the dishwasher is running (green), when it is paused (green flashing), and when the dishes are clean (blue). What is happening to me is I will start a cycle and it will run a little while, and then randomly the light starts flashing as if the door had been opened and it won't continue to run. So I open and close the door, press start, and it will run a little while longer...I basically do this about 20 times in the time of a normal cycle. I can't figure out what is causing it to stop mid-cycle.
    Dec 2012
    Fishtail, Montana
    When my husband gets in I will have him give this a try :-).
  1. Replies: 15
    Last Post: March 8th, 2012, 09:08 PM
  2. Replies: 3
    Last Post: March 15th, 2011, 04:48 PM
  3. Sanitize rinse cycle flashes green after cycle
    By B4UR2OLD in forum Sears Kenmore
    Last Post: November 23rd, 2010, 11:05 PM
  4. Freezer randomly stops freezing
    By 2004hokie in forum Sears Kenmore
    Last Post: October 14th, 2010, 12:00 PM
  5. Replies: 1
    Last Post: December 9th, 2005, 11:30 AM
