Results 1 to 10 of 13
Thread: upper track
    Dec 2012
    johnson city, tn
    Default upper track
    Model Number: KUDE70FXPA1
    Brand: KitchenAid
    I need to replace the track for the upper rack (not the removal top one) and can't see how to replace it. I have the part, but need instructions. Thanks!
    Last edited by Jake; January 2nd, 2013 at 02:15 PM. Reason: Corrected model number
    That model# didn't pull up as good, please recheck it. Read it from the tag inside the tub frame.
    Click here: Appliance Parts at RepairClinic. 125 Brands. 365 Day Returns.
    Then you will see a link that says: Help me find my model number.
    Also post the part number for that part you received.
    Dec 2012
    johnson city, tn
    Dishwasher model# KUDEFXPA1, part # W10311156. Got the part from appliancepartspros.com, it looks correct, but I'm not sure what the attachment is. Do I pry the old one off, or do I need to pull the whole unit out because the attachment is through the side?
    Ok, when I type that model in appliancepartspros website I get about 20 models: Parts for KUDEFXPA1 - AppliancePartsPros.com
    Now are you reading the model from the tag?
    If you are absolutely thats the correct model# then I'm stumped as well, and I can't help you, you'd have to ask them for assistance.
    Dec 2012
    johnson city, tn
    The model # is correct. Type in the search bar on their main page and it gives diagrams. The part is the side track on the "upper rack and track parts" diagram.
    I did type it in, no diagrams just parts.
    Did you look to the left where it says: Matching Model Numbers If you click any of those 20 model numbers then you get the diagrams for that model.
    Take a digital photo of your model number tag and post it here.
    Dec 2012
    johnson city, tn
    Dec 2012
    johnson city, tn
    Default Picture
    Figured it out!
    See you were missing the 70 between the "E" and "F".
    Thats what I needed.
    Now to change it you have to pull the dishwasher out and you will see screws on the outer tub assembly that holds mounts it in place.
  1. Replies: 3
    Last Post: August 12th, 2012, 01:54 PM
  2. top rack track part replacement
    By Bonnie in forum KitchenAid
    Last Post: May 16th, 2012, 04:10 PM
  3. Upper arm not spinning, etc
    By cajunmama in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 30th, 2011, 09:54 AM
  4. Upper arm does not rotate
    By eewoz in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 21st, 2007, 12:19 AM
  5. Kitchenaid dishwasher upper track question
    By gatordoug in forum KitchenAid
    Last Post: April 9th, 2007, 01:20 AM
