Results 1 to 2 of 2
Thread: Kenmore elite he3t. rear bearings
    Apr 2011
    Kentucky
    Default Kenmore elite he3t. rear bearings
    Model Number: 110.42926202
    Age: More than 10 years
    Hi
    Out washer was knocking when ti spun. I took off the back and am checking the bearings. What I found is the pictures. There was a metal washer wedged in the bearings. The other washer was still intact but was bent badly. See pics below. i am guessing that the whole bearing assembly needs to be replaced. What is my next move?
ID:	8795Click image for larger version.
ID:	8796Click image for larger version.
    Next move is to remove the inner tub from the outer tub and see if the inner tub has broken or cracked support arms or not, if so, then the cost for both inner and outer tubs would well exceed the cost of a new washer.
    Rear outer tub assembly:
    Manufacturer's Number: W10253866
  1. Replies: 254
    Last Post: March 27th, 2013, 04:24 AM
  2. Rear Bearings Question
    By kandj200 in forum Frigidaire/Electrolux
    Last Post: May 9th, 2011, 11:30 AM
  3. FWT647GHS0 rear bearings and seals
    By brettd24 in forum Frigidaire/Electrolux
    Last Post: June 14th, 2007, 11:03 AM
  4. Rear, bottom leak on He3t - 110.42922200
    By amartin in forum Sears Kenmore
    Last Post: October 10th, 2006, 01:34 AM
  5. Kenmore Elite HE3....rear shocks pulled apart!
    By EXFFPM in forum Sears Kenmore
    Last Post: April 4th, 2006, 12:20 PM
