Results 1 to 3 of 3
Thread: Elements testing 1 ohm 12 hours after replacing
    Jan 2013
    Default Elements testing 1 ohm 12 hours after replacing
    Model Number: E1F50RD045V
    Age: Less than 1 year
    Bought this water heater April 2012.
    -Tested original elements as follows: top 1 ohm and bottom 12 ohms. Both were 4500 watt
    -Bought two brand new 4500 watt elements
    -i replaced the top and bottom elements. The top was cracked and bowed and the bottom simply had a lot of sediment on it.
    -I allowed the tank to fill with the power off and then turned on.
    -We had hot water last night and now this morning have none.
    -Both elements are reading 1 ohm.
    -thermostat reads 240 v.
    How could they have both gone bad that fast?
    Thats very odd, Wish I knew the answer.
    That model# doesn't pull up even on Whirlpool's website.
    You may want to recheck it and see what your warranty is on it, most are 1 full year. Then I'd setup a service call to have Whirlpool come out and see whats going on.
    Jun 2012
    Default Water heater
    Sorry to see you're having problems! Can you contact me directly so I can help?
    Whirlpool Water Heaters Product Support
    Thanks! ~ Chris
    American Water Heater, authorized licensee for Whirlpool Water Heaters
  1. Replies: 1
    Last Post: December 10th, 2012, 11:26 PM
  2. FIXED: No power to radiant elements or oven elements
    By pino in forum Frigidaire/Tappan/Electrolux
    Last Post: May 10th, 2008, 04:59 PM
  3. Frigidaire GSB5755DS HO for 3 hours
    By tshurd in forum Frigidaire/Electrolux
    Last Post: March 12th, 2008, 05:01 PM
  4. neither elements in oven come on, no power to elements
    By sun45 in forum Frigidaire/Tappan/Electrolux
    Last Post: December 28th, 2007, 12:44 PM
  5. Bosch Running for 3 1/2 hours
    By wendysj in forum Bosch
    Last Post: March 14th, 2007, 03:32 PM
