Results 1 to 5 of 5
Thread: Bosch dishwasher, do dishes really dry?
    Apr 2006
    Colorado
    Question Bosch dishwasher, do dishes really dry?
    I am purchasing a new dishwasher. Cost is not the main driver, I would prefer the following features;
    1. Cleans dishes without washing before I load them
    2. Quiet
    3. Adjustable racks
    4. Ability to handle large diameter plates
    I have been told that the Bosch dries very well with no heated dry cycle and I have been told that dishes are always wet. Who is correct?
    The other dishwasher that I am considering is an Asko. Any comments on Askowould also be appreciated.
    Oct 2004
    Just uses the heat built up from the hot water.
    Most today will dry flat dishes and such no problem...anything with a divet on the bottom ( glass cup ) will have water laying in the indent. Using jet-dry helps with the dry cycle also.
    *I* won't be owning one...JMO!
    http://www.applianceaid.com/
    Appliance Repair Aid
    Mar 2006
    pennsylvania
    Water temp above 135 helps, purge the water from your sink before starting dishwasher so the hot water is up to the dishwasher location. Water hardness should be reasonable, jet dry, etc, etc, etc...
    Buy a kitchenaid.
    Apr 2006
    S. Central PA
    Most dishwashers recommend running the faucet before starting and if you dont rinse off or scrape off good you will just be cleaning the screen/sump often..
    Oct 2006
    Florida
    Default Drynot
    They truly do not dry anything as well as less "exotic" models that I have owned. Everything else is superior, but the drying function leaves a lot to be desired.
  1. Bosch Dishwasher "groaning"??
    By pointnshoot in forum Bosch
    Last Post: April 21st, 2011, 11:45 AM
  2. Bosch Dishwasher Problem
    By DanM in forum Bosch
    Last Post: July 2nd, 2007, 10:48 PM
  3. Jenn-air dishwasher not drying dishes
    By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 5th, 2007, 11:54 AM
  4. Bosch Dishwasher will not fill with water
    By sparks70b in forum Bosch
    Last Post: October 11th, 2006, 07:12 PM
  5. Whirlpool Dishwasher does not dry dishes anymore!!! Help!!!!!
    By Bemidji1 in forum Whirlpool/Roper/Estate
    Last Post: August 8th, 2005, 11:52 PM
