Results 1 to 4 of 4
Thread: Kitchen aid dishwasher stopped in middle of cycle
    Apr 2013
    Alameda, California
    Default Kitchen aid dishwasher stopped in middle of cycle
    Model Number: Kuds01dlwh3
    Brand: KitchenAid
    My Kitchenaid dishwasher stopped in the middle of the cycle. The control panel does nothing, no lights either. There is still water in the tub. There is power to the machine as well.
    Jul 2006
    If the machine gets too hot the thermal fuse (#6) on the control board will open. Check it for continuity with an ohmmeter. If it is open, check the heating circuit for any shorts or opens. Here's the one for your machine:
    Thermal Fuse 8193762 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Apr 2013
    Alameda, California
    Rick, I checked the thermal fuse and it does have continuity. I will check the heating coil next, if this has continuity what else could the problem be? Thanks for your help, and by the way how hard is it to remove the heating coil?
    I agree with Rick, but did you check for 120 volts at the junction box underneath the dishwasher where the main power comes in with a multimeter? I've seen those 2 wire nuts there melt and come loose and cause a loss of power as well. Lots of people just check the breaker and see if its tripped, but you actually need to check with a multimeter.
    Here's the heating element kit for your model, comes with a new control board as well:
    Manufacturer part number 8194200 is RepairClinic item number 1094552
    8194200
    Yes, you have to pull the dishwasher out to change the heating element.
    Watch this video:
    To change the control board that you must do as well, watch this video:
  1. Replies: 6
    Last Post: July 19th, 2012, 10:43 AM
  2. FIXED: Stopped Middle Cycle - Water Standing - No Power
    By mandown_1130 in forum Sears Kenmore
    Last Post: December 23rd, 2011, 01:14 AM
  3. FIXED: Kitchen Aid Dishwasher not starting cycle
    By gclower in forum KitchenAid
    Last Post: December 20th, 2011, 12:08 PM
  4. Dryer stopped working in the middle of the load
    By TamiMena in forum Sears Kenmore
    Last Post: May 22nd, 2010, 04:40 PM
  5. Replies: 10
    Last Post: October 30th, 2008, 11:46 AM
