Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Maytag dryer with low heat
    Mar 2010
    Chino
    Default Maytag dryer with low heat
    Model Number: LDG9206AAE
    Brand: Maytag
    I have replaced the coils, the cycling thermostat, the high limit thermostat, the flame sensor, and yet the heat still seems low. It seems to me to be taking too long to dry. Up until about 6 mos ago it was hooked up to a vent run that was waaay too long, and who knows how clogged with lint. We moved, and now the vent run is right, and clear from the blower wheel to the outside. My timer also does not advance in auto mode, but advances fine in timed mode. The only things I haven't changed out are the heat switch, the timer, and the fuse of which I only see one, and it tested fine. Does anyone have any suggestions?
    Thank You, Stephanie
    LDG9206AAE
    Last edited by tinkermaniac; April 17th, 2013 at 11:04 AM. Reason: Correct model #
    Jul 2006
    It sounds like you may be having a problem with the coils on the gas valve. When they get weak they won't always open the gas valve. One way to check it is to watch the igniter glow red and when it clicks off see if you get a flame every time. Most gas dryers have a small plastic plug on the lower front panel (usually the logo) that pops out so you can view the gas valve. Most of the time when they fail, they work normal for the first few cycles then start sticking. If they start sticking closed and there is no flame the cycling thermostat won't open to advance the timer motor in auto dry.
    Gas Valve Solenoid 279834 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2010
    Chino
    Thank you for your response, but... My coils are brand new, they were the first thing I replaced. And I get a flame every time the igniter glows.
    Jul 2006
    Is there any way you can get a temperature reading at the vent. A meat thermometer will work. What cycle are you using for testing? You should be using timed dry high heat and see if that works first.
    Mar 2010
    Chino
    I don't have a "high heat" setting, I only have heat and fluff. I put the dryer on heat, timed dry, and put the meat thermometer right where the air exits the dryer. The lowest temp on my thermometer is 130 it got no where near that. The air coming out the vent on the outside of the house doesn't feel warm.
    Jul 2006
    OK, you have the machine completely assembled, correct? When you first start the machine, can you hear the gas turn on? Does it not come back on?
    Mar 2010
    Chino
    yes, the machine is completely assembled, and I can watch the flame come on every time the igniter glows, through the tiny little peep hole in the front. I hear a significant "click" somewhere around the time the igniter glows and the flame comes on, then a softer kind of "bonk" sound just before the flame goes out.
    Jul 2006
    And you're saying the temperature at the vent is less than 130*F on timed dry, heat. It sounds like an air flow problem. Check the blower wheel and see if it's stripped on the shaft and the housing isn't packed with lint. It sounds like the gas valve assembly is working correctly. Since you replaced the cycling thermostat already, either there isn't enough air flow and the flame piles up on the cycling thermostat keeping it from getting hot or the contact points in the timer are burned not letting the correct voltage get to the gas valve. You can set your meter to measure VAC and disconnect the two wires going to the gas valve and insert your meter probes, one in each wire. Start the machine and slowly rotate the timer through the timed dry setting. Watch the voltage on you meter it should remain at 110 VAC.
    Mar 2010
    Chino
    Yes, the temp in the vent never even got close to 130. I have checked the blower wheel, and it is not clogged, and it turns with the drum movement. The vent run is completely clear from the lint trap all the way to the exterior vent flapper door. At this point I think it would seem to me that the timer is the issue, since it seems everything else has either been replaced, or is working correctly. What do you think?
    Jul 2006
    Don't replace it without checking it. It's not common for that style timer to fail very often.
    Timer 33001624 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. Maytag dryer won't heat.
    By Detailslady in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 8th, 2012, 06:53 PM
  2. Maytag dryer no heat on inteli sensor cycles heat on timed cycles. Serial # 31450268YU
    By blue_jassid in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 28th, 2011, 11:59 AM
  3. Maytag Dryer=no heat
    By nbws6 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 6th, 2007, 10:53 AM
  4. Maytag gas dryer, no heat
    By kiiski in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2007, 10:15 AM
  5. Maytag dryer won't heat
    By gigimarie in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 16th, 2006, 07:07 PM
Tags for this Thread
