Results 1 to 3 of 3
Thread: Kenmore Quite Guard
    May 2013
    michigan
    Default Kenmore Quite Guard
    Model Number: 587.14012405
    So it fills up and drains fine..the problem im having is that it will not wash..i reached underneath it and wiggled the housing where the motor/pump is located. it started to work but very weak now it dosnt even come on..so does it sound like the pump/ motor?
    May 2013
    michigan
    any help?
    When it goes into the wash cycle, use a multimeter to check for 120 VAC at the two wires on the circulation motor. If the voltage is correct, replace the circulation motor:
    Circulation Pump 154859201 Order now for same day shipping. 365 day return policy. RepairClinic.com
    This is how you do it; Power off, insert the meter probes into the wire connector on the motor. Make sure the meter is set to check VAC. Power on, start dishwasher on a normal cycle. After the machine fills, it starts the wash cycle. Make sure you have all heated wash, sani-cycle turned off. When the machine starts the wash cycle your meter should indicate 120 VAC. If the voltage reading is correct and the motor is not running the motor needs to be replaced.
    This video should help if you need to replace the circulation motor:
  1. FIXED: Kenmore Quiet Guard problem
    By SSLaser in forum Sears Kenmore
    Last Post: July 9th, 2014, 10:40 AM
  2. Kenmore Quiet Guard 4 not washing. Help please.
    By sloliver in forum Sears Kenmore
    Last Post: January 3rd, 2012, 08:03 PM
  3. No Power on Kenmore Quiet Guard Ultra
    By TxAero in forum Sears Kenmore
    Last Post: July 18th, 2010, 11:23 PM
  4. Kenmore Dryer/Wrinkle Guard Issue
    By thelark31 in forum Sears Kenmore
    Last Post: March 27th, 2006, 01:11 AM
  5. Kenmore Elite Wrinkle Guard 2
    By jwv651 in forum Sears Kenmore
    Last Post: December 16th, 2005, 12:49 PM
Tags for this Thread
