Results 1 to 4 of 4
Thread: Quiet Partner II won't drain
    Jun 2013
    Ohio
    Default Quiet Partner II won't drain
    Model Number: DU1100XTPS9
    Just yesterday, after running a load of dishes, opened the door to find a bunch of dirty water at the bottom that won't drain. When I push the drain/cancel button, I hear the motor running, but it doesn't sound like it normally does - like it's getting air. I've checked for an obstruction and didn't find one. When you take the pump off and turn it on, the fins spin. Any idea what the problem could be?
    Oct 2004
    Likely clogged/restricted somewhere....you checked all the way from the d/w to the house drain?
    Dishwasher Washing Problems | Appliance Aid
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jun 2013
    Ohio
    Yes - i've checked for an obstruction and didn't find one.
    Oct 2004
    *If* the drain is good and the drain pump is getting power ( 110-120 volts AC ) the drain pump itself would then be suspect....might run with no water and stall when acually asked to work...
Size:  2.7 KB Drain pump Manufacturer Number 8558995
  1. Quiet partner II wont drain
    By adoregon in forum Whirlpool/Roper/Estate
    Last Post: February 6th, 2012, 12:35 PM
  2. FIXED: Whirlpool Quiet Partner IV won't drain...
    By robrocco in forum Whirlpool/Roper/Estate
    Last Post: February 3rd, 2011, 11:58 AM
  3. [FIXED] Quiet Partner II won't drain
    By Tom1231000 in forum Whirlpool/Roper/Estate
    Last Post: December 23rd, 2010, 12:57 AM
  4. Quiet Partner I (DU915PWKS0) won't drain
    By amorak in forum Whirlpool/Roper/Estate
    Last Post: April 15th, 2009, 10:23 AM
  5. Quiet Partner skipping drain cycle
    By Geof in forum Whirlpool/Roper/Estate
    Last Post: December 7th, 2007, 11:13 PM
