Results 1 to 6 of 6
Thread: GE Gas range burner ignitor(s) not clicking
    Nov 2010
    Illinois
    Default GE Gas range burner ignitor(s) not clicking
    Model Number: JGBP24GEJ3AD
    Brand: GE
    Age: More than 10 years
    The year old thread (link below) describes the problem I have with a gas range - right side burner ignitor(s), for either the front or rear burner, does not click/fire unless the left side burner is lit or ignitor is firing.
    http://www.applianceblog.com/mainfor...-not-work.html
    For a JGBP24GEJ3AD model, is the fix the same?
    Does each burner have its own ignitor switch? Do both the front and read (right side) burners use the same ignitor switch, or separate ignitor switches for each? Or is the replacement an assembly of multiple ignitor switches?
    Where is the ignitor switch located?
    Dan
    Oct 2004
    Yes.
    Seperate switches.
    Nope.
    For sure check the switches AND wiring between them and electrodes.
    Under the knobs on the control shaft.
Size:  3.0 KB Spark ignition switch Manufacturer Number 316035200
    http://www.applianceaid.com/
    Appliance Repair Aid
    Nov 2010
    Illinois
    Thank you for your comprehensive reply and the part number. Dan
    Oct 2004
    Your welcome, if you get a change let us know what happens
    Nov 2010
    Illinois
    I got the front bezel plate off and exposed the switches, but the switches appear to have heat shrink tubing around the field wire connections to the switch:
    How does the replacement 316035200 switch connect to the field wiring? Solder? tiny screw terminals? butt joint crimp connections? Mini-push-on connectors?
    Oct 2004
    Push on small spade connevtors...
  1. Burner Ignitor Doesn't Always Spark
    By qman in forum Sears Kenmore
    Last Post: January 13th, 2013, 12:29 PM
  2. Top burner ignitor replacement
    By Dede in forum Frigidaire/Tappan/Electrolux
    Last Post: October 31st, 2012, 01:22 PM
  3. Whirlpool Super Capacity 465 - Oven Burner Ignitor
    By Slymber in forum Whirlpool/Roper
    Last Post: September 9th, 2010, 09:55 PM
  4. Frigidare Range/Oven FGF378WCCA ignitor, need to lift range top
    By JeanetteL in forum Frigidaire/Tappan/Electrolux
    Last Post: November 21st, 2006, 11:23 PM
  5. GE XL44 Left Front burner ignitor inoperable
    By Ian in forum GE/Hotpoint
    Last Post: October 10th, 2005, 10:54 PM
