Results 1 to 4 of 4
Thread: Maytag Oven taking a long time to heat up
    May 2006
    Houston
    Default Maytag Oven taking a long time to heat up
    Model Number: PGR4410CDW
    Brand: Maytag
    Back again......and way to soon. It's the oven this time.
    Model - PGR4410CDW
    Serial - 14391512CE
    Our oven is taking a long time to heat up. My wife set it for 450 and after five minutes it felt like it wasn't even on yet. It took about 10 minutes before it started getting hot inside and 15 minutes before it reached the desired temp.
    Any suggestions as to where to start looking?
    Oct 2004
    Check the igniter first, if ok then the temp control is suspect, a weak ignitor is often the trouble maker....
ID:	11371 Ignitor, glow bar vertical mount Manufacturer Number 74007498
    LINK> Gas Range Repair Help | Appliance Aid
    Ignitor is checked with an amp meter. Should draw 3.2-3.6 amps to be good.
ID:	11372 Oven thermostat Manufacturer Number 74002390
    http://www.applianceaid.com/
    Appliance Repair Aid
    May 2006
    Houston
    Got the ignitor today and switched it out. Oven is working like a champ. Thanks guys!!!
    Oct 2004
    Thankx for the update
  1. FIXED: Cooktop taking a long time to heat
    By 95husker in forum Whirlpool/Roper
    Last Post: April 20th, 2013, 04:05 AM
  2. FIXED: gas oven was taking a long time to preheat, and now has stopped heating at all
    By RJHuff in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 15th, 2012, 11:24 AM
  3. Kenmore Dryer Taking a long time to dry
    By ando1 in forum Sears Kenmore
    Last Post: September 13th, 2009, 09:50 AM
  4. Whirlpool Duet taking long time to dry
    By lowe408 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 29th, 2009, 06:13 PM
  5. Oven taking too long to heat up
    By fadgmo in forum Sears Kenmore
    Last Post: June 8th, 2007, 12:48 AM
