Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Maytag MFI2568AES ice2O ICE MAKER NOT WORKING
    Jul 2013
    Virginia
    Default Maytag MFI2568AES ice2O ICE MAKER NOT WORKING
    Model Number: MFI2568AES
    Brand: Maytag
    MAYTAG MFI2568AES Ice maker stopped working. I tried unplugging and warming the ice maker cavity with a hair dryer to see if anything was frozen with no luck. I noticed that there is No water in the cube making reservoir. I Read another older post on here where it suggested replacing the dual water valve.
    I replaced the valve but it is still not working. There is still no water filling the ice maker reservoir. The cold drinking water feature in the door works well and there are no water pressure issues. We bought this unit new in june 2008 and have had no issues otherwise. Freezer temp is zero and fridge is @ 40.
    the older thread I mentioned goes to the point where the gent replaced the valve but his still wasn't working and the thread ended.
    What else could be the issue? Any help is appreciated.
    Fairway
    Jul 2006
    Look inside the fill tube and see if there is any ice build up blocking the water fill for the ice maker. If the fill tube is clear and the water valve is new, replace the ice maker.
    Ice Maker Assembly W10519364 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2013
    Virginia
    I thawed the unit with a hair dryer. The unit is totally emptied and I have it powered off for eight hours with all doors open and a floor fan blowing in it. I have noted no ice meltage or any signs of water. It's still not working.
    Is there something in the ice maker that controls water flow? What about that circuit board on the back I moticed?.
    Thanks for the reply!
    Fairway
    Jul 2006
    Quote Originally Posted by Fairway View Post
    Yep, The cam opens and closes the contact points for the water valve.
    MFI2568 SERVICE TEST
    The service test functions are performed using the refrigerator display and keypad. Enter the Service
    Test Mode by performing the following sequence of events:
    1. Press and hold the Door Alarm Keypad.
    2. Press and hold Refrigerator Temperature Up Keypad.
    3. Release the Door Alarm Keypad and wait 3 seconds.
    4. The Freezer display will display SE confirming entry in the Service Mode.
    5. Press the Refrigerator Up Keypad again to confirm entry in the Service Mode.
    6. Display will show 101 in left display and numeric or dashes in right display.
    7. Press Freezer Up Keypad and Freezer Down Keypad to toggle through Service Test numbers.
    8. To exit service test mode, open and close refrigerator door or hold door alarm for 3 seconds.
    ICE MAKER ISSUES:
    SERVICE TEST–113
    ICE COMPARTMENT FAN
    Press the Refrigerator Up keypad and Refrigerator Down keypad to toggle Ice compartment Fan On High speed, Low speed and Off.
    NOTE: Display will show state 0.0 for OFF, 11.0-14.0 volts for High speed or 7.75- 8.25 volts for Low speed.
    SERVICE TEST–145 ICE BOX THERMISTOR
    Will Show Ice Box Temperature or, OP open thermistor or SH shorted thermistor.
    SERVICE TEST-192
    ICE MAKER STATE TEST
    Display shows “dr” if left fresh food door switch is in the door open position.
    Display shows “OFF” if ice maker power switch is in the off position and door closed.
    Display shows “On” if the ice maker power switch is in the on position and the door closed and heater is off.
    Display shows “OnH” if ice maker power switch is in the on position and harvest heater is on and door closed.
    SERVICE TEST-193
    ICE MAKER RELAY
    Press the Refrigerator Up Keypad or Refrigerator Down Keypad to toggle the ice maker relay On and OFF.
    Jul 2013
    Virginia
    When will the P/N you recommend be available?
    Jul 2006
    RepairClinic and AppliancePartsPros both show it out of stock. You'll need to ask them when it will be available.
    Rick that ice maker kit you posted above says Replacement ice maker, 220 Volt
    220 Volt??? Surely that's not the one for any USA models?
    Jul 2006
    That's the correct ice maker for that model. The control board steps up the voltage to lower the amps Energy Star
    WOW, Very interesting, that's a new one on me.
    Thanks for pointing that out.
    Now I can go back to my Jack Daniels and meditate on that awhile.
    Jul 2006
    Jack Daniels??!! I have a very extremely detailed explanation on how that works if you invite me over!Name:  Smiley 2.jpg
  1. Maytag MFI2568AES IceMaker Not Working
    By LT_Smash in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2015, 07:30 PM
  2. Replies: 0
    Last Post: October 1st, 2011, 04:40 PM
  3. Maytag MFI2568AES can't program.
    By G.Spell in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 24th, 2011, 09:28 PM
  4. Maytag MFI2568AES Ice Maker trouble
    By sm00th1 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 30th, 2009, 10:45 AM
  5. Maytag Ice2O Ice maker not working
    By fredge in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 29th, 2007, 12:46 AM
