Results 1 to 6 of 6
Thread: fridgidaire timer switch
    Jul 2013
    nw indiana
    Default fridgidaire timer switch
    Model Number: MRS26LGJB2
    Brand: Frigidaire
    Hi, I have been having intermittent problems with this side by side. I have found turning the timer under the freezer's door will start it. And it may start and run one or several times. When it doesn't start I have no defrost or condenser fans? Does this make any sense? I would appreciate any help. Artie
    Last edited by Jake; July 20th, 2013 at 12:11 AM. Reason: Added complete model number
    Oct 2004
    MRS26LGJ
    10 models start with those digits...the rest are?
    Where is my Model Number? | Appliance Aid
    What is the issue that is making you turn the timer?
    The refrigerator doesn't always start when you turn the timer?
    The defrost and condensor fan motor shouldn't be on at the same time anyways.
    Nope.
    Not what you are doing or think is wrong....what is or is not happening would be a good place to start.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jul 2013
    nw indiana
    Thanks, Jeff1, I had a hard time finding the rest of the numbers. MRS26LGJB2 serial # LA03617020
    I tried wiggling connectors, etc, and found this switch under the freezer door and did the what do I have to lose? I turned it, the compressor and the fan in the freezer and the cooling fan for the compressor all started, and cooled. What else can I check for you to help me? Thanks, Artie
    Oct 2004
    Soooooo the original complaint was the refrigerator was sitting there dead with the lights on and making no sounds??
    If yes, it is possible for the defrost timer to stick in a defrost mode....manually advancing the timer and the refrigerator jumps back to life......but it should be back to temp after approx 4-6 hours of running......is it?
    If yes...
Size:  2.6 KB Defrost timer assembly Manufacturer Number 215846602
    Jul 2013
    nw indiana
    Thanks Jeff, When I was following the circuit for the compressor, is when the defrost switch went to defrost, removing power to the compressor. I have it running and the switch did what is intended.
    The issue started when all lights, fans, were on, and a no-start on the compressor. I could see a small drop in voltage, and the compressor would click, an overload was tripping. A soft tap from a deadblow hammer started it.
    We have been experiencing some power outages, and I would wonder what would happen if the compressor wanted to start under load? It has been 3 days that the unit sat, before I could get to trouble shooting it. Would the valves be that tight, not to allow the system to balance? I know some automotive AC.
    The fridge has been running in my garage for 2 days without any problems, including defrost.
    Would 2 days be enough time for a test run?
    Thanks for all your help, and sorry about some of the confusion, Artie
    Oct 2004
    A real observation/complaint
    Another good observation.
    Compressor clicking on and off with everything else still running.
    Bad start relay/overload, bad compressor, low voltage ( extension cord, etc ), dirty condensor coils, condensor fan motor not running/not running properly are common trouble makers.
    When the power goes off and comes right back on is when that is an issue....still can equalize through the cappillary tube.
    Should be.
    Compressor clicking helps..
    Refrigerator Repair Help | Appliance Aid
Size:  2.9 KB Starter PTC Manufacturer Number 218721110
  1. Timer or Push to Start Switch?
    By Lefteye in forum Sears Kenmore
    Last Post: July 16th, 2012, 10:06 AM
  2. Timer switch?
    By bandb-bc in forum Frigidaire/Electrolux
    Last Post: November 28th, 2010, 10:59 AM
  3. Loose Timer Switch??
    By athenshome in forum GE/Hotpoint
    Last Post: July 22nd, 2010, 08:51 PM
  4. Kenmore 70 Series Timer Switch?
    By Black Widow in forum Sears Kenmore
    Last Post: June 11th, 2006, 03:58 PM
  5. How to Remove the Timer Switch
    By delroy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 7th, 2006, 12:32 PM
