Results 1 to 10 of 10
Thread: Whirlpool Side by Side Refrigerator is not Cold/Freezing?
    Jul 2013
    Dayton, Ohio
    Default Whirlpool Side by Side Refrigerator is not Cold/Freezing?
    Model Number: GS5SHAXNB00
    I have a Whirlpool "Gold" Side by Side Refrigerator (GS5SHAXNB00). Noticed yesterday that the freezer was not cold and ice cream was melting. Slowly has gotten worse and ice has started to melt today. Opened up the panel to look at condenser coils and there was no frost?
    I can hear the unit kick "on" for like 5 seconds then it kicks off. This repeats every 5 minutes or so. Refrigerator side seams to be cool, but hard to tell if the temperature has also dropped on that side.
    Any suggestions would be greatly appreciated... thanks!
    Rick
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    May 2008
    on the frying pan
    Sounds as though you have a sealed system (Freon) issue or might need a hard start capacitor (it may force the compressor to run but if no/low Freon it will not cool of course). I believe the freezer feeds cold air to the fridge. Might need to call in the repairman- but wait for a reply from Jake if can.
    That's your evaporator coil behind the back panel inside your freezer, your condenser coil is underneath your refrigerator.
    Sounds like your compressor start relay went out.
    Follow this guide to check it to see if it rattles: [FIXED] How to replace a (Whirlpool/Kenmore Model 106) Refrigerator Start Relay
    Here's the compressor start relay for your model you can order:
    Whirlpool 2319792 Start-Dev - AppliancePartsPros.com
    Jul 2013
    Dayton, Ohio
    Thanks for the information Jake... I thought that I might have had the wrong terminology on the "coil", sorry about that. After reading through some more of the other post, I agree that the relay might be the culprit. It's not just the freezer side that is not keeping temp, we had to relocate all the refrigerator items this afternoon due to it also not keeping cool. I will remove first thing in the morning and let you know what I find out.
    Thanks so much for your help.
    Rick
    Jul 2013
    Dayton, Ohio
    Decided to go ahead and take it apart tonight. It does "rattle", so I assume it has gone bad. Just a quick confirmation... I assume that I only need to replace the Start Relay and not the Run Capacitor? See attached picture for my specific part... thanks again for all of your help!!!
    Rick
    Correct Rick, just replace the compressor start relay, and not the run capacitor.
    Jul 2013
    Dayton, Ohio
    Thanks Jake. I was able to pick up the part this morning. But before I pulled out of the parking lot, I wanted to make sure the part fit my capacitor. It does... but I noticed that the NEW part rattles when I shake it... just like my existing "bad" part. It doesn't look like it was installed, but the packaging was a little "shady".
    My question... Is there anyway to tell if the new part is defective other than installing it to see if it solves the problem?
    Oh boy, that's not good. Where was this place you bought it at?
    They didn't have anymore you could exchange it for?
    Jul 2013
    Dayton, Ohio
    Sorry for the late reply, but was out of town.
    I purchased it from "Dayton Appliance", they are a distributor here for most of the local guys, so I figured I'd go to the source and not pay markup. It was the "last one" they had on the shelf so I took my chances and installed it before I had to leave. Seams to have done the trick, ice-maker was working the next morning and it has been working all week. The "rattling" concerned me, hopefully it will last???
    Once again, thanks for all your help Jake... save me some serious headache and $$$$.
    Rick
    Ok Rick, sounds good.
    Are you a tech? Reason I ask is that all appliance parts distributors have to mark up the price a little to cover their operating costs, so unless your a tech. they won't mark up the price, because techs have to mark it up a little when they install it on a customers appliance.
    Usually parts from AppliancePartsPros or RepairClinic, are less expensive than local appliance parts distributors, and you have 365 days to return the parts for a full refund, less shipping, for any reason period! Even if you install the part/parts including electrical parts. Most local appliance parts distributors can't even come close to matching that.
  1. Whirlpool Gold side by side freezer thawing and refrigerator freezing
    By Kenspeeds357 in forum Whirlpool/Roper/Estate
    Last Post: October 25th, 2012, 10:41 AM
  2. Whirlpool side by side refrigerator not freezing meats
    By Desertrose0317 in forum Whirlpool/Roper/Estate
    Last Post: September 5th, 2012, 09:45 PM
  3. Replies: 11
    Last Post: July 22nd, 2012, 02:47 PM
  4. Replies: 1
    Last Post: February 10th, 2012, 07:00 AM
  5. [FIXED] Magic Chef Side-by-Side Freezer cold but Refrigerator side warm
    By k2bzee6 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2010, 11:25 AM
