Results 1 to 8 of 8
Thread: Kenmore Heavy Duty 70 Series wont drain fully
    Aug 2013
    New Oxford, PA
    Default Kenmore Heavy Duty 70 Series wont drain fully
    Model Number: 110.82870820
    Age: More than 10 years
    My washer will go through all cycles and when it turns off the clothes are still soaking wet and have suds on them.
    I removed the cabinet and jumped the lid switch out. Replaced the pump and checked all hoses. Ran it without the cabinet and the pump is turning and a small amount of water is going to the drain.
    HELP we are leaving for vacation in 3 days and need to get some laundry done!!
    Oct 2004
    Something between the tanks ( coin, clothing ), something caught in one of the hoses would be prime suspect.
    Removing the basket helps..
    Direct Drive Washer Access Procedures | Appliance Aid
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jul 2006
    If you just replaced the pump and only a small amount of water is draining out, there's a blockage in the hose either between the bottom of the tub and the pump or the drain and the pump. Either that or the new pump is bad.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Dec 2011
    fla
    Default ricks appliance of largo fla.
    Quote Originally Posted by rickgburton View Post
    could have a kinked hose or mabe the breakclutch is slipping.
    Dec 2011
    fla
    could be a kinked hose or the brakeclutch is not spinning fast enough .
    Jul 2006
    It's a direct drive machine ricks appliance, the pump is attached to the motor so transmission, clutch, brake, spin tube or tub it doesn't matter what's spinning and what's not spinning as long as the motor is working and if one of those washer parts was slowing the motor it would kick off on the overload. The only hose that could kink is the drain hose and that's hard to do when the drain hose connection is at the bottom of the machine and the drain hose is usually just long enough to reach the drain. My guess would be the blockage is a sock between the drain and the pump.
    Dec 2011
    fla
    thanks for the information rick
    Jul 2006
    Anytime my friend!
  1. FIXED: Kenmore heavy duty 70 series washer won't drain
    By pbgcmw in forum Sears Kenmore
    Last Post: July 26th, 2011, 12:22 PM
  2. [FIXED] 70 Series Heavy Duty Spin and Drain Problem
    By rogeris1 in forum Sears Kenmore
    Last Post: July 26th, 2011, 10:06 AM
  3. [FIXED] Kenmore Series 80 Heavy Duty Fills wont Engage
    By IdahoSpud in forum Sears Kenmore
    Last Post: October 20th, 2010, 01:54 AM
  4. 70 Series Super Heavy Duty Won't Drain or Spin
    By Midwife in forum Sears Kenmore
    Last Post: October 12th, 2008, 10:27 PM
  5. Replies: 4
    Last Post: August 24th, 2006, 04:57 PM
