Results 1 to 10 of 10
Thread: KitchenAid dishwasher water won't drain
    Aug 2009
    London
    Default KitchenAid dishwasher water won't drain
    Model Number: KUDM01FKSS1
    Brand: KitchenAid
    My dishwasher has water that will not drain, it seems clean. I've vacuumed it out and cleaned any debris that was in the chopper, ran another cycle and it was still not draining.
    What could it be?
    thanks
    Oct 2004
    Is the drain pump working? Often start with, is the drain pump getting power or not.....getting power and the drain system ( all the way from the d/w to the house drain ) is clear = new drain pump time...
ID:	12114 Drain pump assembly Manufacturer Number 661658
    http://www.applianceaid.com/
    Appliance Repair Aid
    Aug 2009
    London
    how do i know if the drain is getting power, i do have a multimeter reader, but where and how do i test the pump?
    Oct 2004
    Quote Originally Posted by nigel_miguel View Post
    2 wires going to the motor...
ID:	12124 See them on the bottom of this pic.
    ...set the d/w to drain, set meter to test 120 volts AC and touch one meter lead to one of the wires to the pump and other meter lead to the other wire going to the pump.
    Aug 2009
    London
    I've touched the multimeter leads to each wire from the pump. And I'm getting a reading of 08.0 and 07.9 What does that mean?
    Oct 2004
    At the same time?
    and I'm getting a reading of 08.0 and 07.9 What does that mean?
    Across the 2 wires?
    If yes, that would be no power to the drain pump.
    Aug 2009
    London
    So if there is no power to the drain pump, what's the problem?
    Oct 2004
    A broken/bad wire between the control and pump is always possible, esp where the door bends to open and close...this is rare but very possible. Failing that, no power fom the control
Size:  3.5 KB Electronic control assembly Manufacturer Number 8564543
    Aug 2009
    London
    So I disconnected the two leads from the drain motor and I connected the multimeter to the leads with the dishwasher running a rinse cycle and I get 40.6 Volts. Is that ok?
    Oct 2004
    Nope, should have 110-120 volts AC across the wires when the drain pump is engaged.
  1. Replies: 6
    Last Post: January 5th, 2012, 12:19 AM
  2. Replies: 3
    Last Post: November 15th, 2011, 07:24 PM
  3. Replies: 1
    Last Post: October 4th, 2011, 10:27 PM
  4. KitchenAid Dishwasher Wont Drain
    By Peterp in forum KitchenAid
    Last Post: March 8th, 2011, 10:39 AM
  5. KitchenAid dishwasher won't drain
    By jkir in forum KitchenAid
    Last Post: January 1st, 2007, 11:13 PM
