Results 1 to 3 of 3
Thread: Need help with replacing top rack adjuster
    Aug 2013
    Iowa
    Default Need help with replacing top rack adjuster
    Model Number: KUDS30FXSS8
    Brand: KitchenAid
    The axles on the top rack adjuster broke (what silly fragile dealeos those are). I have the replacement part in hand, W10350376, but can't figure out how to get the broken ones off and replace them. Anyone have a PDF manual around? Or can point me somewhere?
    Thanks in advance,
    Oct 2004
    Not sure if these help but I found....
    Used screwdriver to pry apart main clip that attached adjuster to top of rack. There were 5 clip type pieces in total and analyzed right hand adjuster as model for reassembly.
    I took the broken basket adjuster off and then attached the new one. It wasn't too difficult, however some removal instructions and re-install instructions( or just a picture supplied) would have been helpful. This isn't an issue for a mechanically inclined person, but would be a challenge for someone that isn't
Size:  3.2 KB Dishrack adjuster Manufacturer Number W10350376
    http://www.applianceaid.com/
    Appliance Repair Aid
    Feb 2014
    United States
    I had the same problem with the broken rollers. I've come up with a fix so that you never have to buy another rack adjuster. See my YouTube video: Kitchenaid W10350376 Rack Adjuster Fix.
  1. 665.13263K110 Kenmore replace upper rack adjuster
    By HandyAndy in forum Sears Kenmore
    Last Post: October 13th, 2012, 10:54 AM
  2. Top rack not getting any water
    By gamiclea in forum KitchenAid
    Last Post: December 7th, 2010, 06:47 PM
  3. rack adjuster stabilizer piece?
    By novice repairman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 24th, 2010, 10:52 PM
  4. Top rack never gets wet
    By kb5sej in forum Sears Kenmore
    Last Post: March 30th, 2010, 02:56 PM
  5. Replacing Top Rack Of Kuds220t
    By klinger in forum KitchenAid
    Last Post: July 31st, 2007, 01:22 AM
