Results 1 to 10 of 10
Thread: GE PFS22SISBSS Temperature sensor location
    Aug 2013
    California
    Default GE PFS22SISBSS Temperature sensor location
    Model Number: PFS22SISBSS
    Brand: GE
    Can someone let me know where the temperature sensor location is in the fridge section.
    Jul 2006
    It's located on the ceiling of the fresh food compartment behind the light assembly. Use a flat blade screwdriver under the thermistor cover and then squeeze the cover at the bottom to get it off. It might be foamed in and you'll need to dig it out to get to the wires.
Name:	GE PFS22 Thermistor 01.jpeg
ID:	12240Click image for larger version.
Name:	GE PFS22 Thermistor 02.jpeg
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2006
    Yes sir! That's the one .
    Excellent Rick, thanks for confirming that.
    Aug 2013
    California
    Awesome, thanks guys.
    Jul 2006
    Hmm...not a bad idea for this model:
Name:	REFRIGERATOR DO NOT RESUSCITATE.jpg
    Aug 2013
    California
    I took the cover off for the sensor. How far should the wire leads attached to it come out?
    Jul 2006
    Far enough that you can cut the wires and strip 3/4" insulation off each one. Then you'll need to use the supplied crimp connector to crimp the ends to the new thermistor and fill the crimp connector with RTV silicone. You'll probably need to cut some of the wire off the new thermistor so it will go back in the spot it came from.
    Aug 2013
    California
    Quote Originally Posted by rickgburton View Post
    Thanks, i was only able to get the old sensor out so far. I cut off the old sensor almost to the end of it and had about 4" of wire coming out of the fridge. I spliced it and it seems to be good. I didnt want to pull the old wire out too far since it seemed either short or binded up. Hopefully it works. I checked the old sensor and it 5.35K Ohms at ambient temp. Hopefully its out of spec at 37F
  1. Simplicity Model sye3700 Oven temperature sensor location
    By Pantagruel in forum Ranges/Ovens
    Last Post: October 10th, 2011, 10:43 AM
  2. Temperature Sensor Going bad
    By nysecretweapon in forum GE/Hotpoint
    Last Post: January 23rd, 2011, 03:58 PM
  3. How to tell if a temperature sensor working properly?
    By ronnyruiz in forum Frigidaire/Tappan/Electrolux
    Last Post: November 23rd, 2010, 04:13 PM
  4. Turbidity sensor location?
    By fjp33 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 1st, 2010, 09:12 PM
  5. Location of Aqua Sensor
    By vmili in forum Bosch
    Last Post: April 14th, 2006, 08:20 AM
