Results 1 to 2 of 2
Thread: GE Quiet Power 3 problems
    Sep 2013
    montana
    Default GE Quiet Power 3 problems
    Model Number: GHDA485N00CS
    Brand: GE
    My GE dishwasher has issues a door latch issue with tthe interlock switch and handle actuator (wont always come on have to repeatedly close the door) also I see it is on a recall for the heater element causing a fire and now it has started leaking out the bottom , I can pull panels to get to my washer and was looking at it from behind and it appears the leak is coming from the tub not by any fittings. Any ideas as to what could cause the leak ? and is it worth fixing ?
    Your model takes two door switches.
    Here's the door switch for your model:
    Interlock Switch WD21X10224 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video:
    Here's the door handle actuator for your model:
    Handle Actuator WD13X10045 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Access the inside of the door. Slide the spring onto the actuator hinge pin and hook the spring into the hole on the actuator. Snap the actuator into the bracket, making sure the spring arm rests in the channel of the actuator bracket. Install the handle and reassemble the door on the unit.
    For the leak issue I've used this product for washer and dishwasher tub leaks:
    Whirlpool 27615P Sealant (red 3M800) - AppliancePartsPros.com
    Its expensive but it works because its resistant to washer and dishwasher detergent.
  1. FIXED: GE Quiet Power 3 - No Lights on Display After Power Failure
    By terrymunroe in forum GE/Hotpoint
    Last Post: April 19th, 2013, 02:04 PM
  2. GE Quiet Power 3 Problems
    By texastreetops in forum GE/Hotpoint
    Last Post: January 24th, 2012, 02:10 AM
  3. GE Quiet Power #
    By Hannah.S in forum GE/Hotpoint
    Last Post: May 5th, 2011, 12:30 PM
  4. Quiet Power 1 Problems
    By QP1 in forum GE/Hotpoint
    Last Post: April 24th, 2011, 01:06 AM
  5. Quiet Power 3 continued cleaning problems
    By SunCoast4 in forum GE/Hotpoint
    Last Post: March 24th, 2011, 11:12 AM
