Results 1 to 8 of 8
Thread: Kenmore He3 - no heat
    Nov 2008
    connecticut
    Default Kenmore He3 - no heat
    Model Number: 110.92826101
    We have a Kenmore He3 (model# 110.92826101) gas dryer that no longer heats up. Can you please let me know what the diagnostic procedures are? Thank you in advance for your help.
    Nov 2008
    connecticut
    I took the front cover off and noted that the igniter is works intermittently. Thanks.
    You will need a multimeter to ohm test and volt test.
    Remove the lower panel and start the dryer on high heat, timed dry cycle and watch for the igniter to glow red. If it does, you'll hear the valve click and the igniter will turn off and the gas will ignite.
    If this is what you observe, or if there is no flame, replace the gas coil assembly on the valve.
    If the igniter doesn't turn on, disconnect the connector for the igniter and check for 115 VAC going to the igniter. If the voltage is correct, replace the igniter. If the voltage is incorrect, the problem is elsewhere.
    Here's the igniter for your model you can order here:
    Dryer Igniter 279311 Order now for same day shipping. 365 day return policy. RepairClinic.com
    You can also ohm test the igniter, Watch this video to ohm test your igniter:
    Here's the gas coil assembly for your model you can order here:
    Gas Valve Solenoid 279834 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch the video below to replace them, the video shows just a normal Whirlpool/Kenmore Dryer, yours is a HE3 so the bottom lower access panel comes off with 2 1/4" screws at the very bottom near your floor, other than that the video should be the same as far as replacing the gas coil assembly.
    Nov 2008
    connecticut
    Thank you for your direction. Since my original post, I took the front cover off and noted that the igniter works intermittently and that the burner will shut off while the drier cycle continues. Thanks again for all your help.
    Nov 2008
    connecticut
    Jake, I have continued to try and identify more information to help with the diagnosis. I have cleaned the entire unit. When I reessembled and started the dryer, it ran for 13 minutes and the burner went out while the dryer continued to run. Thanks again.
    Yes, the burner should cycle off once it reaches the proper temperature inside the dryer, now if the burner does not cycle back on, then its the gas coils that are bad.
    Nov 2008
    connecticut
    Jake, the gas coils were replaced and the gas is staying. Thank you. The clothes are coming out very hot to the touch. Is there a thermostat that should be checked? Thanks again.
    Ok, that's good the new gas coils fixed the flame not staying on issue.
    You have a thermistor that controls the heating temperature. Its #42 here: http://c.searspartsdirect.com/lis_pn...2123-00003.png
    Thermistor 8577274 Order now for same day shipping. 365 day return policy. RepairClinic.com
    To get access to it, Unplug or turn the breaker off to your dryer first then remove your lint screen #64, then remove the two #49 screws, then remove the bracket #11 by removing the single #2 screw. Then the lint duct assembly #45 will come off, when you have the lint duct assembly off clean it out real good, I've seen tons of lint build up in those.
    Then your thermistor is #42, take the two wires off of it, then ohm it, Normal should be about 10,000(10K) ohms at room temperature.
    If that checks fine, then there's likely a exhaust vent clog where the hot air exits your house. You will need to check that.
  1. Replies: 1
    Last Post: April 21st, 2013, 07:08 PM
  2. FIXED: Kenmore Dryer Even Heat II stops randomly - Even Heat II
    By BobPot in forum Sears Kenmore
    Last Post: November 24th, 2012, 09:46 PM
  3. Replies: 8
    Last Post: May 30th, 2010, 03:54 PM
  4. Kenmore 80 110.70852990 weird heat/no heat problem
    By Gaidin in forum Sears Kenmore
    Last Post: December 19th, 2006, 01:22 PM
  5. kenmore with no heat
    By stillnumb in forum Sears Kenmore
    Last Post: November 11th, 2006, 01:33 AM
