Results 1 to 4 of 4
Thread: Compressor relay
    Aug 2013
    California
    Default Compressor relay
    Model Number: PFS22SISBSS
    Brand: GE
    Just replaced the mother board and all was well for a few days. Now the temps in the fridge and freezer are not holding. I removed the compressor relay. I guess there are 2 parts the Relay/Start device WR07X10097 and the Run Capacitor WR62X79 Are the 2 holes the ones pointed put in red, the ones i need to Ohm out? When these usually fail do they fail open or closed? I'm getting a open/no reading.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Oct 2004
    Overload, start relay, run capacitor.
    I usually don't, but you can ohm them, should show continuity....open or no continuity would be bad.
    Is the compresor not running?....clicking on and off?
    Compressor start device Manufacturer Number WR07X10097
    LINK> Refrigerator Repair Help | Appliance Aid
    http://www.applianceaid.com/
    Appliance Repair Aid
    Aug 2013
    California
    I think the compressor is running. It's hot, but clicks every couple of minutes. Fan is running and new motherboard. It was good after the motherboard replacement. However it took awhile for the temps in fridge and freezer to come down to set temps. Now they are not holding temps.
    Oct 2004
    Clicking on and off normally is not running....if running for a bit but then clicking off, I would suspect a compressor drawing too much current and shutting of fo nthe overlaod.
    Then may not be relaited if the compressor ran ok after the first repair.
  1. 3 Way Relay for Compressor
    By J&T in forum Whirlpool/Roper/Estate
    Last Post: December 12th, 2009, 10:48 PM
  2. compressor or relay?
    By saintmaniac in forum KitchenAid
    Last Post: September 29th, 2009, 12:14 PM
  3. kitchenaid compressor relay
    By joe here in forum KitchenAid
    Last Post: June 21st, 2007, 11:09 AM
  4. Relay/compressor problem
    By SD-IL in forum Sears Kenmore
    Last Post: June 2nd, 2006, 08:20 AM
  5. Relay/Compressor
    By Angel.Baez in forum Refrigerators & Freezers
    Last Post: March 14th, 2005, 10:31 AM
