Results 1 to 2 of 2
Thread: Error code F20
    Oct 2013
    Weymouth,MA
    Default Error code F20
    Model Number: 110.46462501
    I have a Kenmore HE2 washer. I'm getting code F20. I have changed the pressure switch, hose and pump. When doing a load I get code F20. I do not get it all the time. Around 95% of the time. When you run it in rinse and spin there are no issues. Is there a way to test the pressure switch? Please help!
    What type of fill hoses are you using? if they are those "flood prevention" type hoses they will not work with front load washers and cause the F20.
    Water pressure to the washer fine? Try different water temps, hot, cold warm to see if one works and doesn't show the F20.
    Here's the repair manual for your model(it says Duet Sport, your HE2t is the same as the Duet Sport made by Whirlpool):
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
    Give it time to download.
    You will need to check your pressure switch on page 5-2.
    A few members with this same problem found it was a bad pressure switch.
    Here's the pressure switch for your model:
    Pressure Switch W10163980 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. Replies: 3
    Last Post: September 5th, 2012, 02:44 PM
  2. Fault Code F2 Error Code E6
    By bsmith in forum Whirlpool/Roper
    Last Post: February 20th, 2011, 01:11 PM
  3. Replies: 3
    Last Post: November 1st, 2010, 12:25 AM
  4. error code
    By rudyre in forum KitchenAid
    Last Post: October 17th, 2006, 10:28 AM
  5. Error Code 70
    By wmason in forum Frigidaire/Electrolux
    Last Post: February 16th, 2006, 01:49 AM
