Results 1 to 6 of 6
Thread: Amana Heat Troubleshooting
    Apr 2006
    Chicago
    Question Amana Heat Troubleshooting
    Not sure what the terminology is but here we go…
    Model - LG8319W2 Not Heating Up.
    Vent clean
    Took front cover off
    Thermal Fuse??? (device on exhaust pipe) has 5 each wires connected to it, when I check ohms at the connections opposite each other they zero out and are good but the lone connection does nothing.
    The large piping that runs into the drum has 2 electronic devices mounted to it, which both pass the ohms test.
    When I start the dryer, the igniter at the end of the gas valve tube glows bright red but no gas is coming from the valve to ignite?
    What do ya think? Do I need a new gas valve or is something telling the valve not to open?
    …perplexed
    Sounds like the gas coils may be out.
    This link should help:
    http://www.applianceaid.com/gas_dryer.html#noheat
    That part on the exhaust pipe with 5 wires is your cycling thermostat, thats rare to go out, its more likely your coils.
    Apr 2006
    Chicago
    Thanks Jake, I just ordered the kit you directed me to.
    Glad to help, keep us posted on the outcome.
    Apr 2006
    Chicago
    Just received the kit, popped it in and the dryer works like a charm. Thanks again for the diagnosis Jake!
    Glad to help, glad to hear that the gas coils fixed it!
  1. amana ale956eaw dryer no heat
    By wally in forum Amana
    Last Post: February 22nd, 2007, 01:57 AM
  2. amana gas dryer lg4409 (w) no heat
    By gravey in forum Amana
    Last Post: February 12th, 2007, 06:26 PM
  3. Amana, inconsistent heat
    By ss750 in forum Amana
    Last Post: September 21st, 2006, 11:48 PM
  4. Amana Dryer Heat on/off
    By billyd89 in forum Amana
    Last Post: July 13th, 2006, 07:56 PM
  5. Amana Dryer no heat
    By bw1 in forum Amana
    Last Post: May 12th, 2006, 03:49 PM
