Results 1 to 3 of 3
Thread: True kegerator compressor not kicking on, hard start kit maybe?
    Sep 2013
    Baltimore
    Default True kegerator compressor not kicking on, hard start kit maybe?
    Model Number: TDD-1
    Brand: other
    Age: More than 10 years
    I recently replaced the compressor on a True kegerator with the help of Rick on this forum. Here is the link to that thread.
    True TDD-1 kegerator, not getting cold - Page 6
    I just aquired another True Kegerator and the compressor is not kicking on. The condenser fan starts as does the evaporator fan inside the cabinet.
    I pulled the overload and relay and tested the compressor per this the instruction on this youtube video
    How To Test A Compressor - YouTube
    Everything tested worked perfectly. I have continuity between all 3 connections on the compressor(start, run and common). I don't have a short to ground either.
    I assume the compressor is locked up.
    What should my next step be?
    Would you recommend installing a hard start kit?
    Thanks.
    Slash
    Jul 2006
    Once the compressor locks up that's about it for the compressor. Years ago I made a box that would break free locked rotors using a reversing switch and 220 VAC. The best that would do is buy some time. Replace the compressor if it's worth it.
Name:	Ricks Appliance 042.jpg
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Sep 2013
    Baltimore
    Thanks for the quick reply Rick. That is a very cool box you built.
    I'll order another compressor tomorrow.
    Thanks again.
    Slash
  1. True TDD-1 kegerator, not getting cold
    By slash5bmw in forum Refrigerators & Freezers
    Last Post: December 27th, 2013, 11:10 PM
  2. Compressor kicking out
    By GideonOmega in forum Samsung
    Last Post: December 2nd, 2013, 08:41 AM
  3. TRUE TDD-4 kegerator fan stays on continuously
    By n8huntsman in forum Refrigerators & Freezers
    Last Post: May 12th, 2013, 05:21 PM
  4. CCA Kegerator F400 bad start relay
    By 250tiger in forum Refrigerators & Freezers
    Last Post: January 23rd, 2013, 07:38 PM
  5. Kegerator compressor not running
    By gunnercooper in forum Refrigerators & Freezers
    Last Post: October 24th, 2006, 09:53 PM
