Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Kitchenaid Dishwasher Superba
    May 2005
    Post imported post
    I have a Kitchenaid dishwasher that quit in mid-cycle. Lights went out on the display panel. There is power to the unit - ends at display panel. Any ideas?
    Post imported post
    If you can post a model# that would help us.
    After it quits in mid cycle, if you touch the display panel buttons, does it start or light up?
    May 2005
    Post imported post
    Pressing any of the buttons didn't seem to do anything - no lights. I will have to look up the model number.
    May 2005
    Post imported post
    The only number I found was one stamped into the door
    287432184
    Liz
    Oct 2004
    Post imported post
    **The only number I found was one stamped into the door**
    Might help
    http://www.applianceaid.com/
    Appliance Repair Aid
    May 2005
    Post imported post
    There was one stamped on the left side of the tub, but it was illegible...was the number I gave you a useless one?
    Oct 2004
    Post imported post
    **287432184**
    Came up as nothing for me.
    Oct 2004
    Post imported post
    On the model number tag?
    Sample Model Number Tag
    If that information on it is not legible, there may be at least part of a model number on the appliance's wiring diagram which is usually behind the lower access panel and a small pocket, pouch or envelope. There will usually be a 'tech sheet' with it which will usually include some diagnostic procedures and may even provide some of the common components' part numbers.
    JFYI
    Appliance411.com
    =D~~~~~~
    May 2005
    Post imported post
    I located the plastic pouch, but it looks like the wiring diagram has been removed. There are some numbers on the electronic parts - would that be of any use? If not, can you suggest what to do next without a model number?
    Thanks for your help!
    Oct 2004
    Post imported post
    **Lights went out on the display panel**
    **If not, can you suggest what to do next without a model number?**
    Maybe have a peek for a blown or bad thermal fuse up beside the control.
    Just a guess!
  1. Kitchenaid Superba KSSS42MW - Repair or replace?
    By udahman in forum KitchenAid
    Last Post: November 30th, 2012, 11:49 AM
  2. KitchenAid Superba dishwasher won't start
    By cmcarter in forum KitchenAid
    Last Post: April 4th, 2008, 10:11 AM
  3. KUDPO2CRBL4 Kitchenaid Dishwasher Door won't open
    By ucsbgrad86 in forum KitchenAid
    Last Post: June 1st, 2007, 03:14 PM
  4. Replies: 2
    Last Post: December 6th, 2006, 12:09 AM
  5. Replies: 2
    Last Post: November 12th, 2006, 12:09 AM
