Results 1 to 4 of 4
Thread: WP Electric Dryer won't run on Autodry cycle
    Jul 2006
    Fairfax, VA, USA
    Unhappy WP Electric Dryer won't run on Autodry cycle
    My sister gave me her 1-year old Whirlpool dryer. This model does not have a separate controller for temperature---instead, I have a single dial controller. The cycles are Fluff Air, Timed Dry (High Heat), Auto Dry (High Heat) and Auto Dry (Low Heat).
    Everything functions perfectly except the Auto Dry-Low Heat cycle. When you select that part of the dial and push the button, nothing happens.
    PLEASE HELP! Of course, I use the low heat setting more than any other setting, and after a week of laundry hell, I have about 30 loads to do this "holiday" weekend.
    Oct 2004
    Model#?
    http://www.applianceaid.com/model.html
    Some model# helps.
    Appliance Repair Aid
    Jul 2006
    Fairfax, VA, USA
    Default Model Number and Type
    Model Number LEC5000PQ0
    Type D433-ELE-2406028-FM54
    Oct 2004
    A nice simple dryer
    Push to start switch, motor, door switch, thermal fuse, ect work on all other cycles = thye should be ok....kinda sounds like the timer itself may be at fault for the one non-working cycle.
    Timer assembly
    The timer contacts can be ohmed for continuity with an ohm meter as per the wire diagram that comes with the dryer to confirm the timer is open/not working in that one cycle.
  1. Maytag Electric Dryer GDE808 - Help!!
    By jbird68 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2008, 11:51 PM
  2. Frigidaire Electric Dryer Only Stays Hot For 5-8 Min
    By Its Broke in forum Frigidaire/Electrolux
    Last Post: November 5th, 2007, 12:37 AM
  3. Duet Gas Dryer: cannot turn off after auto cycle
    By PRK in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 22nd, 2007, 10:56 AM
  4. GE Electric Dryer runs but no heat
    By vdrsolo in forum GE/Hotpoint
    Last Post: September 27th, 2006, 02:44 PM
  5. kenmore electric dryer stops before cycle is complete
    By ragincajundad in forum Sears Kenmore
    Last Post: November 4th, 2005, 04:11 PM
